Feeble bug? or where to get help?
    MrZoon
    Posts: 48 from 2003/6/1
    hiall...
    My son was trying out Feeble Files, and loving it, when he discovered
    that when given a choice of things to say during a conversation with
    another character, the first choice can never be selected. Which
    basically kills the game when there is only one choice (ie. the
    Enforcer in Dave's Bar).
    Is this a known issue? or -- where is the best place to get support
    for this game?
    tia!
    MrZoon ~8
  • »16.11.03 - 03:06
    Robert
    Posts: 331 from 2003/5/12
    @Mr. Zoon,
    The problem you describe does not occur here, although sometimes the
    line you want does not change colour when you hover over it. In these
    cases I've discovered that the active bit of the question mark cursor
    is the pointy bit, at the bottom of the curve.
    Sorry I can't help.
    Robert.
  • »16.11.03 - 22:07
