SongPlayer and ide.device
    DedyAmigo
    Posts: 41 from 2003/7/19
    Who can tell me why songplayer crashes system?
    It`s connect to ide.device unit 2. I have not
    any dosdriver for CD0.
    Thanks for tips and help
    DedyAmigo
    Dedy
    http://amigo.bodli.net
    Powerbook G4/1.67GHz, MOS 3.17 reg
    Asus Zenbook UX32VD, Xubuntu 20.04
  • »13.11.03 - 18:33
    Posts: 154 from 2003/4/22
    Hi !
    SongPlayer sends a wrong/bad command to the ide.device. It makes it
    crash.
    This bugs is fixed in SP internal beta.
    SongPlayer 1.62 release is not very far now.
    Be patient.
    Bye
    MorphOS Rulez !
  • »13.11.03 - 18:55
    Coder
    Posts: 296 from 2003/3/5
    I recently found out you need this in order to play audio cd's. Can anyone tell me which programs will work with this? Meaning which progs I can use to play audio cd's when Songplayer is installed. I like to put this info on my site to for other users.
    MorphOS should play audio cd's out of the box. Period. :-)
    Coder
  • »13.11.03 - 19:12
    poundsmack
    Posts: 1346 from 2003/6/8
    kaya should be able to play them they should implement that into kaya
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »13.11.03 - 19:25
    Posts: 126 from 2003/2/17
    about kaya, it's already implemented in last internal beta :)
  • »13.11.03 - 19:27
    same problem with IDe, but works fine with SCSI CD Drive :)
    SCSI rulez
  • »13.11.03 - 19:28
    Coder
    @poundsmack
    I agree. Kaya is really great. And again, please in a next version of MorphOS have it play audio cd's out of the box. Just the other day I wanted to play a cd from my girlfriend on it and to my shame it did not work. The words (from my girlfriend)..But Windows does.. is bad to hear then.
    Coder
  • »13.11.03 - 19:29
    poundsmack
    @coder
    hahahahaha. so now thats 2 uses for windows (cd, and solitare) well at least there are 2 things its good for :-D
    ps whats the song player website
  • »13.11.03 - 19:32
    Posts: 48 from 2003/5/13
    The URL is : http://amigadev.free.fr/songplayer/indexen.html
    Note we have adviced about the non working CDDA support for IDE devices with SongPlayer 1.60.
    The next release is in betatest, all major changes planned are done now.
  • »14.11.03 - 01:07
    Jupp3
    Posts: 1193 from 2003/2/24
    I use OptyCDPlayer for CD playback.
    Porting some open source CD player (like RexxCD) wouldn't be a bad idea either, I looked at the sources quite some time ago, it sure would need quite a lot work, especially user interface could be improved a LOT... But at least arexx-support is the best I've seen...
  • »14.11.03 - 07:23
