How do I install Python 2.5 to run Blender
    clusteruk
    Posts: 47 from 2010/6/24
    I downloaded Blender and Python and I tried copying Python contents to system but Blender puts up a requester asking for Python v24. Frustratingly I had this working before I had to rebuild. So not sure what I have done diferent.
    I did do a search but found nothing.
  • »11.07.10 - 16:58
    pampers
    Posts: 1061 from 2009/2/26
    Did u try to check what Snoopium says?
    MorphOS 3.x
  • »11.07.10 - 17:43
    clusteruk
    Excuse my Ignorance but what or who is Snoopium?
  • »12.07.10 - 06:39
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Clusteruk!
    Snoopium is a monitoring tool, included in MorphOS: you will find in sys:tool and will let you know if something is missing (or not) when you launch a program. Better: what a program does behind the scenes...
    But I have another question: wich version of Blender are you using? The new 2.5 alpha works without python.library v24. It uses the Python3.library. I put it in sys:libs and it works.
    [ Edited by Jambalah on 2010/7/12 9:51 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »12.07.10 - 06:49
    clusteruk
    @Jambalah
    The only MOS version I can find is v2.46 in the MOS files repository.
    If there is a later version where can I get that. If not am I using the right Python.
  • »12.07.10 - 07:06
    Jambalah
    Blender v 2.46 needs python.library 24 to run. In the files repository you will find two python version. v 2.4.4 and v 2.50. You can download the 2.4.4 and install it to run Blender 2.46.
    Here you will find Blender v 2.50 and Python 2.5.4 r132: Blender 2.50
    To download Python 2.5.4 click 'python' in the "Contents" frame on the left and when it expands, click on 'rel 2.x'. You will find the last python downloads.
    Pegasos II 1 ghz
  • »12.07.10 - 07:29
    clusteruk
    @Jambalah
    Thanks for the reply on this, I missed the standard Python version and just went for the latest thinking that would work. All running with v2.46, will try v.5 later.
  • »12.07.10 - 07:47
