Problems with Sketch
    clusteruk
    Posts: 47 from 2010/6/24
    I have just got an eMac and I am having a couple of problems with my MorphOS installation and want to see if it is something that others are experiencing or there is a tweak.
    With Sketch it seems a bit unstable and especially in the cutting of images I always get an OS lock up. This is frustrating because it looks like a very competent paint application with the kind of functions I use day to day.
    On a side issue, the dock bar which I set up seems to have disappeared. Maybe I stupidly deleted it but I do not know where it is supposed to be.
    Thanks for any help.
    By the way, your version of MPlayer is very nice, wish we had video scaling on Aros, maybe one day.
  • »05.07.10 - 15:21
    stefkos
    Posts: 97 from 2004/2/4
    Please check update option in Sketch (from top menu). If you will still have this problem write to me.
  • »05.07.10 - 15:34
    Get27
    Posts: 90 from 2004/8/23
    Hi Stefkos,
    there is (was?) a little problem with update.
    If you have newer version, it will be replaced by update even if it's older.
    I tested it when MorphOS 2.5 was released.
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »05.07.10 - 15:50
    stefkos
    Right now you can only have latest version.
  • »05.07.10 - 16:33
    clusteruk
    It appears I have the latest version.
    I have a problem mainly with the Stamp button which locks MorphOS and also the Cut and Paste functionality.
    The rest of it seems OK at the moment.
    I do think that this program and Showgirls with its batch process offer some great basic functionality.
    Thanks for the replies.
  • »06.07.10 - 05:15
    amyren
    Posts: 219 from 2010/5/15
    I had the exact same problem with the earlier version, for me this was fixed in the latest version.
    You sure you have version 1.2204 (15.06.2010) ?
  • »07.07.10 - 11:29
    clusteruk
    Interesting, I have 1.22.03 :-)
    But on checking for updates which I did before it says I have latest so how do I get it.
  • »08.07.10 - 06:46
    Posts: 2565 from 2003/2/24
    Dunno, did an auto-update from the MorphOS2.5-version a few days ago and got 1.2204 ....
  • »08.07.10 - 07:05
    amyren
    If it still refuses to update, you could try to copy the old version from the 2.4 CD if you've got it. Maybe it will upgrade from that version.
    Or you can ask the author for a direct link to the archive.
  • »08.07.10 - 08:50
    clusteruk
    I do not have the 2.4 version, and it does not show the new version.
    Is there a way I can manually download.
  • »08.07.10 - 11:04
    Posts: 1354 from 2004/2/8
    There must be a way... somehow... ;)
    /me hopes it's a public beta and Stefkos won't bash me for that...
  • »08.07.10 - 11:42
    Posts: 12543 from 2003/5/22
    Yes, that's the public version you get by using the internal upgrade function.
  • »08.07.10 - 12:03
    stefkos
    Nahh...thx for help with that.
    Sorry for delays in fixing problems with Sketch but there is real life and new app from me.
  • »08.07.10 - 12:16
    clusteruk
    Does that mean it is coming and I will be able to download soon. As you say there is real life and I am in no rush as I have other applications I can use. I look forward to seeing it when it is ready :-)
  • »08.07.10 - 15:25
    Why not download from koszer's link now?
  • »08.07.10 - 15:48
    clusteruk
    @Andreas_Wolf
    Sorry missed that link, DOH!
    edit: All works fine now
    Thanks to all.
    [ Edited by clusteruk on 2010/7/9 13:21 ]
  • »09.07.10 - 09:16
