Posts: 164 from 2009/12/17
I've been using OWB and MorphOS since it was released for MacMini and haven't had too many problems, at least none that couldn't be solved pretty easily. Now I've got a new one: OWB1.8 is having a hard time with Gmail (or is it the other way around). After I log in, any action (move, delete) causes a time-out with a re-try in xx seconds that never works. Switching back to 1.7 it works fine.
Any ideas?
Also, I started getting some SSL errors. The .readme suggests updating the .crt file, but I don't know how to do it. Ignoring these errors fixes things, but is it safe? The .crt file from 1.8 is dated 10/17/2009. Anything newer?
Thanks,
TJH
[ Edited by Travis_H on 2010/7/1 16:18 ]
