Graphing Application on Morph? Any sugestions?
    osco
    Posts: 680 from 2009/10/20
    Quick and dirty histograms needed
     :-D
  • »27.06.10 - 23:43
    jcmarcos
    Posts: 1178 from 2003/3/13
    Maybe they can be done in HTML? At least, bar chart is rather straightforward. But if you want line graphs, no way!
  • »28.06.10 - 05:09
    amyren
    Posts: 219 from 2010/5/15
    Not a MorphOS program, but OWB supports google documents (comes with any gmail account), and there there are some diagrams that can be made. The documents can then be exported in various formats, excel, html, open office, etc
  • »28.06.10 - 05:21
    Krashan
    Posts: 1107 from 2003/6/11
    I've been quite succesfull with generating histograms and graphs using TVPaint via ARexx scripting.
  • »28.06.10 - 05:32
    amyren
    for line graphs, google docs does this as well. Just found this link for an howto:
    line chart howto
  • »28.06.10 - 05:47
    jcmarcos
    CLASS!
    Great, but it would be lovely to make a single call to a certain google URL, which in turn returned a gorgeous PNG file with the chart. Of course, previously, one would have to upload the data there. Can that be automated, or one has to visually create a Google document first?
    [ Edited by jcmarcos on 2010/6/28 10:50 ]
  • »28.06.10 - 05:48
    Tomo
    Posts: 94 from 2003/7/29
    On luckysoft I found a small program called MCC_Plot (in System). It has even ODF-export...
    Perhaps it is easily to expand with differnt charts?
    Regards Tom
  • »28.06.10 - 07:46
    zukow
    Posts: 662 from 2005/2/9
    @Tomo
    I don't have time to finish and develop mcc_plot, all my free time i spend coding SCANdal (about 4 hours per week) and other projects have lower priority. Maybe someone wants to take over it. I can send sources.
  • »28.06.10 - 08:58
    insurgent
    Posts: 64 from 2007/7/8
    @jcmarcos
    I have not played with it yet but you may have a look if there is anything of interest with Google command line tool which was published recently. Needs Python and some other libraries may also be needed. I'm not really sure if everything is there for Google CLI to work in MOS... If it does, it would open all new possibilities.
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »28.06.10 - 09:56
