PDF slideshow?
    osco
    Posts: 680 from 2009/10/20
    Does Morph have an app that will accept a list of files "single page pdf's" and display them in a slideshow format? TIA
  • »20.06.10 - 19:15
    Posts: 12543 from 2003/5/22
    Yes. It's called AmigaDOS (or rather "MorphDOS"?) ;-)
  • »21.06.10 - 00:13
    osco
    /*pdf reader*/
    OPTIONS RESULTS
    IF OPEN(input,test7, R) THEN DO /* opens the batch file of pdf charts in ram:test7, names it input to the script*/
    DO UNTIL EOF(input) /* starts a do loop to the end of file */
    line=READLN(input) /*reads a line (actually a name of a pdf file in ram:*/
    ADDRESS COMMAND OPEN line
    ADDRESS COMMAND WAIT 10 secs
    end
    end
    exit
    WORKS FINE BUT THE DISPLAY CAN ONLY LOADIN APPRX NINE PDF PAGES?
    IS THERE AN ADJUSTMENT TO ALLOW MORE PDF'S ON THE DESKTOP?  :-D  :-D  :-D  :-D
  • »27.06.10 - 23:33
    osco
    Is there a command to close the pdf page in Dos MOS AREXX APDF Ambient etal? :-?
  • »27.06.10 - 23:38
    Tcheko
    Posts: 544 from 2003/2/25
    Have you tried to send CTRL+C to the process ? Typical MUI application exits on CTRL+C signal.
    BTW, why don't you convert the PDF to some picture and use proper slide show program ?
    [ Edited by Tcheko on 2010/6/28 8:31 ]
  • »28.06.10 - 03:28
