Simplemail 'Groups' (solved)
    boot_wb
    Posts: 874 from 2007/4/9
    I'm hoping there is an easy fix I'm missing here.
    I've set up my usual sub-folders within simplemail to store received mails - no problem.
    I've then thought it would be convenient to group these within a group named 'stored' (right click on folder tree, select 'new group', rename appropriately and drag/drop folders into the group - great).
    I then saved the settings (Settings menu>Save settings) even though the grouping is not modified through 'settings,' and just to be doubly sure I opened the config window and saved that too.
    However, when i then close down & reload Simplemail, the group has disappeared. I also cannot appear to save any changes to the order in which folders are displayed.
    Does anyone know if I'm missing something?
    I've just subscribed to the Simplemail mailing list, but am waiting for admin confirmation.
    EDIT: Found it! Main Menu>Folder>Order>Save
    [ Edited by boot_wb on 2010/6/23 16:19 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »23.06.10 - 14:57
