I have obtained some free Chinese / Japanese / Korean (CJK) TrueType fonts. How do I configure OWB 1.8 to use those fonts?
I have copied the new font file to System:Fonts/_ttf folder but they're not visible in MOS Preferences > Fonts. What is required to correctly install these fonts?
Are there any configuration files that have to be set for OWB in System:Applications/OWB/conf/font folder?
Do I need to change encoding settings in OWB Settings > Preferences > Fonts?
The current encoding seting in OWB is ISO 8859-1 but there is no auto-detect option like for some other browsers - does it matter?
I'm trying to setup with these fonts:
http://www.chinesetranslationpro.com/chinese-fonts.phpI never had to do this from scratch so any help would be really appreciated... Thanks!
Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
Dell UltraSharp 2407WFP 1920x1200
PowerBook G4 ready
