Installer improvements
    boot_wb
    Posts: 874 from 2007/4/9
    I understand Guido Mersmann to be the author of installer, but am not sure if he is still maintaining it, so don'tknow who/how to contact about it.
    This is not a bug report, more a feature request.
    Currently, ambient's file browser uses a 'double-click to expand' convention (as do most applications when browsing to open/save files).
    However, installer uses a 'single-click to expand' convention. This is a little confusing, as I (and I'm sure many others) inevitably end up double-clicking, and going further into the directory tree than intended as a result.
    Easy to fix for the user - just navigate back to wehere you want to be - but not condusive to the overall user experience.
    As a suggestion for improvement (especially for new users) I would suggest changing this to a 'double-click to expand' convention to be in line with the rest of MorphOS.
    Regards
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »21.06.10 - 13:14
    Posts: 1096 from 2004/9/23
    For the directory display standard mui dirlist.mcc is used, which has some more issues on MorphOS. Like showing all entries twice sometimes.
    I simply do not use filepanel, because its failing on non MorphOS systems, which is a must as the Installer is ment for more than just MorphOS.
    I may have a look on that later, but currently I don?t have time for this.
    And yes. The installer is still under development.. Latest version can be found here: http://www.geit.de/eng_additional.html
    Geit
    [ Edited by geit on 2010/6/22 0:37 ]
  • »21.06.10 - 14:13
    boot_wb
    Thanks Geit,
    It's good to know who's who around here :-)
    I appreciate it's not a high priority, I'm trying to be a bit more active in terms of suggesting improvements (and also thanking people for their work).
    Thanks for the explanation, I can appreciate the need to maintaining compatibility with non-MorphOS systems.
    Regards
    Rich
  • »21.06.10 - 14:56
