Posts: 680 from 2009/10/21
Using the "Search" command a list of files outputs on the console..They are a list of files..other than a user written script is there a quick "ED" way to make the files "clickable to DOS?
Output of file names clicking on them will open a pdf file
Data:Suf/200907011009wv300en.pdf
Data:Suf/200907131340wv300en.pdf
Data:Suf/200907250945wv300en.pdf
Data:Suf/200908241313wv300en.pdf
How do you make them DOS addressable?
Is it done by MUI Ed Ced Arexx Script?
[ Edited by osco on 2010/6/20 22:05 ]
/*pdf reader*/
OPTIONS RESULTS
IF OPEN(input,test8, R) THEN DO /* opens the batch file in ram, names it input to the script*/
DO UNTIL EOF(input) /* starts a do loop to the end of file */
line=READLN(input) /*reads a line (actually a name of a file in ram:*/
ADDRESS COMMAND OPEN line /*opens the pdf file */
ADDRESS COMMAND WAIT 20 secs /*time to study/read pdf file*/
END
END
[ Edited by osco on 2010/6/24 21:23 ]
