enquetorrent/MLdonkey question
    amyren
    Posts: 219 from 2010/5/15
    Using enquetorrent and MLdonkey for downloading torrents is working. But the user interface is not to easy to use or lacks some options.
    My two issues for now is:
    1. How do I delete a unfinshed torrent download?
    I tried to delete the files in the temp folder and the torrent itself, but this resultet in MLDonkey refused to start until I had deleted all the setup files.
    2. Is there a way to select files inside a torrent for downloading?
    As an example there I found that I was missong an episode in the Lost series and the most promising torrent was the one for the full series. I was not to happy about downloading 37GB for just one episode, so I had to do it on another computer.
    EDIT: Just figured out how to remove a unfinished download. Apearently the letter 'C' in the transfer view stands for Clear, and selecting it and clicking the button 'submit changes' does the job.
    [ Edited by amyren on 2010/6/18 14:33 ]
  • »18.06.10 - 11:51
