[ solved] MOS Software Development Kit 2 don?t install
    _DaNi_
    Posts: 154 from 2010/5/4
    I download the beta SDK2 and i will install it in efika, but when start installation, start the descompressing files and says a error an is stoped. I use the default installation directory. What is this error? I need to download another installer or similar?
    [ Editado por _DaNi_ el 2010/6/9 1:06 ]
  • »08.06.10 - 08:42
    Posts: 3336 from 2003/3/5
    This could be caused by the lack of RAM on Efika. Try to reboot and run the installer w/o starting any other applications.
  • »08.06.10 - 09:18
    Piru
    Posts: 622 from 2003/2/24
    Also, in case you're decompressing the sdk lha to T:, try using a temporary location on some partition instead.
  • »08.06.10 - 09:32
    _DaNi_
    nothing, i try it with no startup-sequence typing in cli installer and says the some error. With no startup-sequence i have available 99mb of free ram
  • »08.06.10 - 09:40
    Piru
    Silly question, but you do have MorphOS 2.5 installed?
  • »08.06.10 - 09:44
    _DaNi_
    yes, of course piru
  • »08.06.10 - 09:48
    Piru
    Hmm, weird. You could try starting Snoopium to see if it fails to get some resource.
  • »08.06.10 - 09:53
    _DaNi_
    i unpack the lha to a temporality dir named temp in sys: i launch the installer aplication for install it and is stopped at 0.05, i try it with no startup-sequence but the some result. I view in sys:/morphos/s/statup-sequence exist sdk entries, i need to rename/delete it?
    [ Editado por _DaNi_ el 2010/6/8 13:53 ]
  • »08.06.10 - 09:53
    The startup-sequence must contain SDK entries - this is fine. Could you tell us what filesystem did you format the system disk with ?
  • »08.06.10 - 10:07
    _DaNi_
    my hdd is formated with SFS 512block and 64buffers
    I put hte log here, when load the las line, installation was stopped
    [1] [ramlib] [Open] [MOSSYS:LIBS/lzma.library.elf] [Read] [Fail]
    [2] [ramlib] [Open] [MOSSYS:LIBS/lzma.library.elf] [Read] [Fail]
    [3] [ramlib] [Load] [MOSSYS:LIBS/lzma.library.elf] [] [Fail]
    [4] [Installer] [Open] [muidebug] [Read] [Fail]
    [5] [Installer] [Open] [MagicWB] [Read] [Fail]
    [6] [ramlib] [Open] [MOSSYS:LIBS/xadmaster.library.elf] [Read] [Fail]
    [7] [ramlib] [Open] [MOSSYS:LIBS/xadmaster.library.elf] [Read] [Fail]
    [8] [ramlib] [Load] [MOSSYS:LIBS/xadmaster.library.elf] [] [Fail]
    [9] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [10] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [11] [ramlib] [Load] [MOSSYS:LIBS/xfdmaster.library.elf] [] [Fail]
    [12] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library] [Read] [Fail]
    [13] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library] [Read] [Fail]
    [14] [ramlib] [Load] [MOSSYS:LIBS/xfdmaster.library] [] [Fail]
    [15] [ramlib] [Open] [LIBS:xfdmaster.library.elf] [Read] [Fail]
    [16] [ramlib] [Open] [LIBS:xfdmaster.library.elf] [Read] [Fail]
    [17] [ramlib] [Load] [LIBS:xfdmaster.library.elf] [] [Fail]
    [18] [ramlib] [Open] [xfdmaster.library.elf] [Read] [Fail]
    [19] [ramlib] [Open] [xfdmaster.library.elf] [Read] [Fail]
    [20] [ramlib] [Load] [xfdmaster.library.elf] [] [Fail]
    [21] [ramlib] [Open] [LIBS:xfdmaster.library] [Read] [Fail]
    [22] [ramlib] [Open] [LIBS:xfdmaster.library] [Read] [Fail]
    [23] [ramlib] [Load] [LIBS:xfdmaster.library] [] [Fail]
    [24] [ramlib] [Open] [xfdmaster.library] [Read] [Fail]
    [25] [ramlib] [Open] [xfdmaster.library] [Read] [Fail]
    [26] [ramlib] [Load] [xfdmaster.library] [] [Fail]
    [27] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [28] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [29] [ramlib] [Load] [PROGDIR:LIBS/xfdmaster.library.elf] [] [Fail]
    [30] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library] [Read] [Fail]
    [31] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library] [Read] [Fail]
    [32] [ramlib] [Load] [PROGDIR:LIBS/xfdmaster.library] [] [Fail]
    [33] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [34] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [35] [ramlib] [Load] [MOSSYS:LIBS/xfdmaster.library.elf] [] [Fail]
    [36] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library] [Read] [Fail]
    [37] [ramlib] [Open] [MOSSYS:LIBS/xfdmaster.library] [Read] [Fail]
    [38] [ramlib] [Load] [MOSSYS:LIBS/xfdmaster.library] [] [Fail]
    [39] [ramlib] [Open] [LIBS:xfdmaster.library.elf] [Read] [Fail]
    [40] [ramlib] [Open] [LIBS:xfdmaster.library.elf] [Read] [Fail]
    [41] [ramlib] [Load] [LIBS:xfdmaster.library.elf] [] [Fail]
    [42] [ramlib] [Open] [xfdmaster.library.elf] [Read] [Fail]
    [43] [ramlib] [Open] [xfdmaster.library.elf] [Read] [Fail]
    [44] [ramlib] [Load] [xfdmaster.library.elf] [] [Fail]
    [45] [ramlib] [Open] [LIBS:xfdmaster.library] [Read] [Fail]
    [46] [ramlib] [Open] [LIBS:xfdmaster.library] [Read] [Fail]
    [47] [ramlib] [Load] [LIBS:xfdmaster.library] [] [Fail]
    [48] [ramlib] [Open] [xfdmaster.library] [Read] [Fail]
    [49] [ramlib] [Open] [xfdmaster.library] [Read] [Fail]
    [50] [ramlib] [Load] [xfdmaster.library] [] [Fail]
    [51] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [52] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library.elf] [Read] [Fail]
    [53] [ramlib] [Load] [PROGDIR:LIBS/xfdmaster.library.elf] [] [Fail]
    [54] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library] [Read] [Fail]
    [55] [ramlib] [Open] [PROGDIR:LIBS/xfdmaster.library] [Read] [Fail]
    [56] [ramlib] [Load] [PROGDIR:LIBS/xfdmaster.library] [] [Fail]
    [57] [Background CLI] [Open] [shellppc.prefs] [Read] [Fail]
    [58] [Execute] [Open] [SDK:Startup] [Read] [Fail]
  • »08.06.10 - 10:19
    Piru
    It would be useful to see the successful calls as well (disable the "show only fails" option).
    But this log already suggests that your MorphOS 2.5 installation is incomplete. Are you sure you're booting the MorphOS 2.5 system and not for instance the morphos-2.5-efikainstall.img ?
    [ Edited by Piru on 2010/6/8 16:50 ]
  • »08.06.10 - 10:46
    _DaNi_
    Piru now is installing! I found the error, in my sys:libs/xad i have some extra package from 68k archive, i rename it and i test with only files in sys:morphos/libs/xad suplied with mos2.5 and now is installing.
  • »08.06.10 - 10:58
    Piru
    Oh! This sounds like some bug in some of the 68k clients you had installed (or alternatively some issue with the xadmaster itself).
    Could you provide a lha archive of the clients and send them to sintonen@iki.fi ?
    [ Edited by Piru on 2010/6/8 18:32 ]
  • »08.06.10 - 11:05
    _DaNi_
    yes, i send you now
  • »08.06.10 - 11:18
    Piru
    I installed the files but I cannot reproduce the problem. The installer works for me every time. Hmmm
  • »08.06.10 - 12:21
    _DaNi_
    here with my external xad in sys:libs dont install sdk2 but without it i install with no problems, is strange
  • »08.06.10 - 13:47
    Piru
    Ok I managed to reproduce it now. It's xfd-xad client it seems. I'll be investigating some more.
    UPDATE
    xfd-xad 1.0 is seriously broken. It will ALWAYS identify every file as xfd-xad if xfdmaster.library is not found or if xfdAllocObject fails.
    This causes the problems you're having. I'll probably add blacklisting for this buggy client to the next MorphOS xadmaster.library version.
    Meanwhile you're advised to uninstall the xfd-xad client ( delete libs:xad/xfd-xad )
    [ Edited by Piru on 2010/6/8 21:04 ]
  • »08.06.10 - 14:13
    _DaNi_
    ok, i dont use my external package 68k, only the default morphos xad. Thanks piru, piru rulez :)
  • »08.06.10 - 14:57
