Reggae updated
    Posts: 12572 from 2003/5/22
    Anyone?
  • »30.03.10 - 12:16
    Tcheko
    Posts: 544 from 2003/2/25
    Experienced once a crash with a jpg picture. This was solved by updating to latest reggae classes.
    Are your classes uptodate?
  • »30.03.10 - 12:41
    Are there newer versions of the ones I mentioned?
  • »30.03.10 - 12:55
    Tcheko
    Maybe you should ask rzokool ( i think i mispelled his nick...) directly. He is the maintener of thoses classes IIRC.
    Morphos-files is sadly not up to date for reggae classes. Those jfif classes are missing for ex.
    Krashan ! Push them all !
  • »30.03.10 - 13:18
    Krashan
    Posts: 1107 from 2003/6/11
    Done.
    Now it is up to date with 3-rd party classes and up to date with official classes compared to MorphOS 2.4. MorphOS 2.5 release will bring more classes and updates for many existing ones.
  • »30.03.10 - 14:58
    Tcheko
    Krashan, it looks like that morphos files is down.
    Thanks for reggae classes !
  • »30.03.10 - 16:37
    Brumiga
    Posts: 277 from 2004/4/3
    @Krashan,
    I have just downloaded your latest reggae files and copied them, but I still have the same crash than tcheko with multiview and jpeg/jfif pictures. So I verified the versions, they are the same nor their md5 sums. So what have you done to these files since their latest updates and their previous ones in november/december 2007 ?
    Brumiga
  • »30.03.10 - 18:12
    Krashan
    It is temporary. Works now.
  • »31.03.10 - 02:54
    Krashan
    They are not mine. Most of these classes are written by Michał Żukowski, as clearly stated in their descriptions.
    I've done nothing. Blame Michał if there is no changelog. I guess grabbing a crash log and sending it to Michał is the best solution for the whole problem.
  • »31.03.10 - 02:58
    zukow
    Posts: 662 from 2005/2/9
    as i see, krashan have uploaded my old decoders/demuxers to morphos filets, so there is no changes in them, i have very little time now (and i live in different flat now without peg and mac mini, only having powerbook here so i'm waiting for new morpos release). During Easter i will be making new scandal drivers, maybe i will have some time for reggae coding.
    I can send my decoders to morphos team also to include it new into morphos releases.
  • »31.03.10 - 04:44
    jcmarcos
    Posts: 1178 from 2003/3/13
    Thanks for the information, Michal. It's a pity you don't have enough time. Will Reggae have MPEG classes soon?
  • »31.03.10 - 06:11
    I think you just have to compare the version.revision of your classes to the ones I mentioned. Then we'll know if your classes are newer than mine :-)
  • »31.03.10 - 23:03
    It's me having the crashes, not Tcheko. He said he solved his crash by upgrading (whatever).
  • »31.03.10 - 23:04
    Any news on the problem with Multiview and jpeg.demuxer/jpeg.decoder?
  • »09.05.10 - 19:56
    zukow
    i've prepared the new version:
    this version make use of jfif.library so it's smaller, i have several version of jpeg.decoder on my HD and i don't remember which is the proper one:D, so this version should work but may crash :)
    http://brain.umcs.lublin.pl/~rzookol/download/jpeg.decoder
  • »10.05.10 - 15:04
    zukow
    http://brain.umcs.lublin.pl/~rzookol/download/jpeg.decoder-51.6.lha
    stable? version
    some fixes, and dpi metadata handling (useful for SCANdal, requires morphos 2.5 :) )
    if you have problem with this decoder just write to me and send jpegs which cause problems
  • »29.05.10 - 19:08
    zukow
    hmm, it looks like this decoder has problem with multiview (or multiview has problems with this decoder). I don't have access to morphos machine til wednesday and then i'll look into.
    with Sketch and morphos it seems work ok
    ps. morphos 2.5 (new multimedia.class) is required for DPI handling only
    ps2. on the other side, Krashan's gif.decoder has problems with some gifs in SCANdal/Sketch :)
    [ Edited by zukow on 2010/5/31 11:46 ]
  • »31.05.10 - 06:45
    > this decoder).
    I can confirm that it's still the same behaviour like was reported before in this thread. Multiview crashes instantly when attempting to load any JFIF file.
  • »31.05.10 - 10:32
    Updated Multiview from MorphOS 2.5 doesn't make a difference.
  • »04.06.10 - 00:32
    zukow
    but updated jpeg.decoder should:
    http://brain.umcs.lublin.pl/~rzookol/download/jpeg.decoder-51.7.lha
  • »04.06.10 - 19:02
    It does, indeed. Thank you very much :-)
  • »04.06.10 - 22:00
