DateCalc
    Krashan
    Posts: 1107 from 2003/6/11
    I've just released a beta version 0.4 of DateCalc, which is a simple calculator for dates. Main features are:
    - Adding or substracting number of days to/from any date.
    - Calculating day difference between two dates.
    - Determining weekday of a date.
    - 7 programmable preset buttons and "Today" button.
    - Program is localized (no *.cd file available yet).
    - Time range is from year 1 to 9999 using proleptic gregorian calendar.
    Program is available here. As it is beta, there is no manual, icon and readme file yet. The interface is mostly self-explanatory however. You can discuss any bugs or feature requests here. DateCalc is freeware and will stay freeware in the future.
    [ Edited by Krashan on 2010/5/9 8:12 ]
  • »09.05.10 - 03:57
    Jambalah
    Posts: 820 from 2008/3/30
    Nice! tested and it worked (it's working) with no problem. Thanks!!
    ... ehm... I couldn't find the MorphOS 2.5 preset key...  :-)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »09.05.10 - 06:36
    Krashan
    DateCalc 0.5
    - Icon added.
    - Polish locale.
    - *.cd file for translations to other languages (German is done already, will be included in the next version).
    - Many minor GUI fixes.
    [DOWNLOAD]
  • »10.05.10 - 10:49
    koan
    Posts: 303 from 2005/11/21
    Suggestions:
    Enter any date to get the day name.
    Conversion to and from Japanese calendar (Nengo). For the Japanese calendar you need to keep a list of the reign of each emperor; for example 2010 A.D. <-> Heisei 22.
    Conversion to and from Thai calendar (Buddhist era). For the Thai calendar you add 543 to the date, 2010 A.D. <-> 2553 B.E. I think some other countries may also use B.E.
    +2 more weeks button  :-D
  • »10.05.10 - 17:39
    Krashan
    It is simple. Enter the date as the first argument, then press either "+ Days" or "- Days" (it does not matter which one), then immediately press "=". The second argument will be automatically set to 0. Then you have the weekday name in the result.
    As for any exotic calendar - I can easily add them for output format, allowing input for them is another story however. For example you can't enter these Japanese dates with only numerical keys...
  • »10.05.10 - 17:56
    Krashan
    DateCalc has got Polish, German and Italian locale. More translations anyone? :-)
  • »11.05.10 - 15:08
    beworld
    Posts: 673 from 2010/2/10
    Hi !
    in french :
    http://beworld.perso.sfr.fr/datecalc
    BeWorld
    My MOS ports
  • »11.05.10 - 16:04
    patbest
    Posts: 43 from 2009/12/21
    Hello Krashan,
    My Folder Icon for DateCalc if you want
    http://www.lafarigoule.org/morphos/download/DateCalc.lha
    Regards
    Patbest
  • »13.05.10 - 10:05
    Krashan
    DateCalc 1.0 is released and available on MorphOS Files. Features of this version:
    - A few minor bugs fixed.
    - User manual in English and Polish.
    - Nice program icon.
    - Translations in German, French, Italian and Polish.
  • »26.05.10 - 02:29
