OWB 1.7 crash on Google Docs - Forms
    amyren
    Posts: 219 from 2010/5/15
    Finally managed to make a connectiom without using the company proxy network:)
    Here is a open network available, but its wifi only, so thats why I couldnt connect directly with MorphOS.
    I solved this by setting ut a portable xp-home pc with some router enabling software. This pc is connected via wifi, and then I connected the mini to the ethernet interface. (strugling a bit with this part)
    But now I can access gmail and google docs without trouble :)
  • »18.05.10 - 17:23
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Ok, so that's indeed down to proxy support in CURL, i guess. For next version, i've updated CURL to 7.20.1, but i don't see anything that would indicate a fix in HTTPS/Proxy, but we'll see. :)
  • »18.05.10 - 22:34
    jcmarcos
    Posts: 1178 from 2003/3/13
    Microsoft Windows to the rescue! :-D
    Let's see if there's any luck. FABtastic!
  • »19.05.10 - 06:51
    amyren
    hmmf, yes. rather annoying isn't it..
    But there was some comfort in the fact that winxp did not manage to handle this alone. Maybe because this was Home edition and not Pro, I could not get the routing to work out of the box. So I found some easy to use software, named NAT32, which does the job. Unfortunately this is shareware with a time limit of 2 hours, then I must restart the program again.
    Ironicly, I just got rid of the 30 mins timeout in MOS (got my keyfile today), and now I get another time limit to worry about:)
    Fab: The next version is ready for release soon? (I noticed the OWB 1.8 teaser video looking promising)
  • »19.05.10 - 09:01
