OWB Failure to receive data
    osco
    Posts: 680 from 2009/10/20
    www.equibase.com fails to receive data?
    dual boot mac / safari receives www.equibase.com no problem!
    I batched fed a session of local html files and i may have changed the settings?
    It is just this site I think.
    Isther a way to get back to default OWB save reinstall?
    Unable to Load Page
    A problem occurred while loading the URL http://www.equibase.com/
    Error 56: Failure when receiving data from the peer.
    [ Edited by osco on 2010/4/30 20:24 ]
  • »30.04.10 - 17:40
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It also doesn't work with Ibrowse, Sputnik here. No idea what it can be, but it doesn't look like it's OWB's fault, at least.
  • »30.04.10 - 22:19
    osco
    Happy
  • »30.04.10 - 22:22
    osco
    I think it may be my fault :( I batch processed of html files that were in Ram: I think OWB somehow used some old urls attached and pounded equibase.com with them..I thinkthey are now allergic to anything Morphos ..I'm sorry If i do it again I will disconnect the ethernet cable.
  • »30.04.10 - 22:51
    osco
    i acceess blogger using a proxy proxytea.appspot.com,it's obvious that
    this website is blocked by the isp.
    but could you tell me there are tools of detecting if a website is
    blocked by isp?like m-lab ddoes
    Can Morphos have a proxy to access www.equibase.com /
  • »12.05.10 - 12:51
  • Fab
    Fab
    You can tell OWB to use a proxy by setting HTTP_PROXY ENV variable with the proxy address (i'll put it in settings someday :)).
    No idea if it will help or not. I don't have any proxy to try.
  • »12.05.10 - 13:01
    osco
    http://home.versatel.nl/roberthoenselaar/ProxyTutorialForAnonymity.html
    a list of free proxys2)Finding the right proxy
    -Free proxy-lists at:
    -www.samair.ru/proxy (1000 proxys with country + anonymity)
    -www.atomintersoft.com/products/alive-proxy/proxy-list (1000 proxys with anonymity)
    -www.proxymatrix.com/index.html (with country + anonymity)
    -www.stayinvisible.com/index.pl (20 pages of proxys. with country + anonymity)
    [ Edited by osco on 2010/5/12 12:37 ]
  • »12.05.10 - 13:35
    Rajinder
    Posts: 38 from 2010/3/24
    would be nice feature for obw to have proxy mode, where it joined a tor network or linked into a free proxy service.
    sorry have have said along these lines before....
  • »12.05.10 - 17:06
    osco
    By a 3-2 vote, the commission on Friday concluded that Comcast monitored the content of its customers? internet connections and selectively blocked peer-to-peer connections.
    The selective blocking of file sharing traffic interfered with users? rights to access the internet and to use applications of their choice, the commission said.
     :-D
  • »18.05.10 - 07:11
