Installer crash
    Kokos
    Posts: 26 from 2009/10/27
    I have a problem with installer of BarsnPipes 1.05 for MOS on my MorphOS 2.4.
    Look inside my Snoopium log:
    [1] [installer] [Open] [PROGDIR:Catalogs/polski/Installer.catalog] [Read] [Fail]
    [2] [installer] [Open] [PROGDIR:Catalogs/polski/Sys/libs.catalog] [Read] [Fail]
    [3] [installer] [Open] [MOSSYS:LOCALE/Catalogs/polski/Sys/libs.catalog] [Read] [Fail]
    [4] [installer] [Open] [LOCALE:Catalogs/polski/Sys/libs.catalog] [Read] [Fail]
    [5] [installer] [Open] [env:Installer.prefs] [Read] [Fail]
    [6] [installer] [Open] [envarc:Installer.prefs] [Read] [Fail]
    [7] [installer] [Open] [PROGDIR:Catalogs/polski/Aboutbox_mcc.catalog] [Read] [Fail]
    [8] [installer] [Open] [PROGDIR:installer.info] [Read] [Fail]
    [9] [installer] [Open] [env:mui/Dirlist-Format.txt] [Read] [Fail]
    [10] [installer] [Open] [muidebug] [Read] [Fail]
    [11] [installer] [Open] [MagicWB] [Read] [Fail]
    [12] [installer] [Open] [installer] [Read] [Fail]
    [13] [installer] [ToolType] [APPBANNER] [] [Fail]
    [14] [installer] [ToolType] [LANGUAGE] [] [Fail]
    [15] [installer] [ToolType] [SCRIPT] [] [Fail]
    [16] [installer] [ToolType] [NOLOG] [] [Fail]
    [17] [installer] [ToolType] [NOPRINT] [] [Fail]
    Installer starts, I can select drive to install and then..
    [18] [installer] [MakeDir] [DH2:BarsnPipes] [] [Fail]
    [19] [installer] [Open] [Ram Disk:BnP_MOS_Install/BnP] [Read] [Fail]
    Installer says: "line: 87; command: "copyfiles"; error: can't open source file"
    Strange thing is that directory is created by installer, and the files exist in RAM device (tried also with other storages).
    I can't recall now, but i guess i had similar problems erlier with other software installers on my MOS, so maybe my OS is damaged or something..
    Thanks for any suggestions,
    K
  • »04.05.10 - 17:41
    Posts: 1362 from 2004/2/8
    Try the famous, classic installer by Commodore and report if it crashes too.
  • »04.05.10 - 19:34
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Well, crash doesn't seem the right word for an installer failure to find some file, anyway. :)
  • »04.05.10 - 19:46
    Kokos
    Still learning. ;)
    Thanks for reply. I'll try that.
    -> http://de5.aminet.net/util/misc/Installer-43_3.readme is it original installer? :)
  • »05.05.10 - 04:05
