Posts: 725 from 2003/2/20
About features, I remembre that : Bochs emulates only a VGA card in 640X480 16 colors. This is very very poor. On this resolution, you cant do a lot of things.
Bochs is very unstable on my pegasos and it is not fast. I can say it is slowwwwwwwww.
If you dont use mouse, but only keyboard with shortcuts, it can be usable, but if you use mouse it's the hell !
I know Stability and speed depends a lot on the settigns, but I tryed with some settings files from a lot of good people using bochs and the best speed I gave is slowwwwwwwww.
Question : Is the last bochs evolution capable to emulate a bigger graphic card?
