Posts: 680 from 2009/10/20
I have a legacy Amiga application "Batch Factory". It is a Batch Processer and Arexx front end.
It is in its initial use and has a problem. A "SCRIPT SELECTION WINDOW will open and prompt you to choose the desired script. This window flashes in a milisecond and disapears? The program freezes the mouse and a reboot is needed. Will Snoopium tell me what is happening? Is there a HOW TO for Snoopium
Clue1? By removing the ASSIGN in the user start-up the 'Script Selection Window " reappeared but was not reading from the hard drive...the lined template for choosing a file was there with no choices?
Clue2? Seems like a conflict of the old application tieing into the MorphOS DOS Guessing?
[ Edited by osco on 2010/4/20 16:13 ]
Clue3? It seems a problem of the file requester? The appliction can read and show the directories devices and assigns
[ Edited by osco on 2010/4/20 16:26 ]
[ Edited by osco on 2010/4/20 16:29 ]
