Html5?
    osco
    Posts: 680 from 2009/10/20
    Is the beta down at Youtube? Show a question mark icon for page?
  • »01.04.10 - 01:41
    Mi-Go
    Posts: 95 from 2003/9/18
    It's still a beta: not all of the videos open in html5 mode.
    Sometimes opening a page from an internal youtube link can do the trick...
    M.
  • »01.04.10 - 07:04
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @osco
    It seels they broke the HTML5 support today.
    By the way, if you see a question mark (on a lego brick?), that means you haven't installed the flash plugin (not that the flash plugin is really fast enough to play youtube, anyway, but still).
  • »01.04.10 - 11:04
    Posts: 12572 from 2003/5/22
    Yes, there're already users complaining about broken HTML5 support in the comments to http://youtube-global.blogspot.com/2010/03/new-video-page-launches-for-all-users.html
    I hope that's just an oversight on Google's part.
  • »01.04.10 - 11:51
  • Fab
    Fab
    They apparently fixed HTML5 support now.
  • »02.04.10 - 20:13
    osco
    Worked then didn't :-?
  • »02.04.10 - 21:16
    igracki
    Posts: 471 from 2003/2/24
    GetVideo also didn't works;(
    Also Tubexx...
  • »03.04.10 - 09:28
  • Fab
    Fab
    Yes, they managed to fix it for a couple minutes and then broke it again. At worst, you can use the flash plugin, and retrieve the video direct URL in message window (or flash resource window), and pass that link to mplayer.
    [ Edited by Fab on 2010/4/3 15:23 ]
  • »03.04.10 - 11:23
    igracki
    GetVideo v0.25 does it again!
  • »03.04.10 - 17:11
    Posts: 1390 from 2010/1/6
    ...and where can we get v0.25....?
  • »03.04.10 - 17:45
    igracki
    He uploaded it to aminet, should be there soon
  • »03.04.10 - 18:14
  • Fab
    Fab
    They also fixed HTML5 again (until they break it again).
  • »03.04.10 - 18:40
    @igracki:
    Thank you for info....hope Tubexx will also come up soon.....
    [ Editiert durch Amigaharry2 an 2010/4/4 0:27 ]
  • »03.04.10 - 19:27
    Mi-Go
    HTML5 is working again on some pages.
    Also flashless is broken because it relies on keep-tube.com which began using java...
    M.
  • »04.04.10 - 08:39
    jcmarcos
    Posts: 1178 from 2003/3/13
    Dontcha love this kind of sittuation, when we realize just how big dependencies we have developed, in this perfect world, with freedom of choice?
  • »05.04.10 - 04:52
    Cego
    Posts: 738 from 2006/5/27
    @jcmarcos
    that was deep my brother...
    :D
  • »05.04.10 - 09:07
    amiga4001
    Posts: 454 from 2006/11/16
    There is no update for tubexx available?
    Or is the problem with youtube site?
  • »06.04.10 - 03:15
    Yes.
    See my posting from 5 days ago.
  • »06.04.10 - 05:44
    I wrote to the autor of Tubexx - he will fix it soon..... meanwhile you can use getvideo......
    Supplement: TUBEXX is fixed! Look at http://www.webalice.it/pgermano/tubexx/main.html
    [ Editiert durch Amigaharry2 an 2010/4/6 21:13 ]
  • »06.04.10 - 16:05
    Divinity
    Posts: 532 from 2009/9/8
    @Fab
    I have problem at the moment with Youtube HTML5 videos, Do you think It's a my problem in OWB config (I use 1.7 version) or a problem of Youtube ?.
    Thanks a lot for your very good software (in particular OWB and Mplayer, I love them, and also for your very good games porting), Do you have a PayPal ?.
    Best regards
  • »18.04.10 - 18:28
  • Fab
    Fab
    Well, what kind of problem do you have? Youtube works in HTML5 mode at the moment, at least.
    (and yes i have a paypal account, but i don't advertise it :))
  • »18.04.10 - 19:03
    Divinity
    @Fab
    I select a movie in YouTube, then opened the page, then I see "Go Upgrade!" and no window of the movie.
    Tell me if I need to make some "debug" to find the problem : - ).
    Ok tell me where/how find you paypal account : - )
  • »18.04.10 - 20:24
  • Fab
    Fab
    You have to go to http://www.youtube.com/html5 first and click the subscribe link, else Flash is used instead. And not all movies are available as HTML5 either, since it's still in test phase.
  • »18.04.10 - 20:52
    Divinity
    thnaks Fab, all OK now : - )
  • »19.04.10 - 13:48
