Database options for MorphOS
    insurgent
    Posts: 64 from 2007/7/8
    I'm in search of software that can manage data in a database. I'm aware of MUIBase and I believe there is a port of SQLlite.Is there a GUI for SQLlite? Any other databases?
    Thanks 8-)
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »17.04.10 - 07:11
    Posts: 1383 from 2010/1/6
    Old MAXON-Twist does also run, but will have some troubles with displaying windows navigation-bar (no text but is usable)....other functions are ok (as far as I've seen......).
  • »17.04.10 - 07:30
    analogkid
    Posts: 715 from 2004/11/3
    A quick search on Aminet discovered a 68k-port of MySQL 4 (IIRC there was a MorphOS-port, too).
  • »17.04.10 - 08:22
  • tom
    tom
    Posts: 149 from 2003/7/22
    I'm an enthousiastic user of MUIBase. It is very powerfull and flexibel and with LISP the programmable options are almost unlimited. I even wrote a Latex-editor in MUIBase.
    (see Aminet ) And I am not a very skillful programmer....!
    And... it's free!!!
    Regards Tom
  • »17.04.10 - 13:23
