Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
E-UAE MorphOS, keyboard question.
CountRaven
# 1
Posts: 566 from 2007/12/11
Benn using the version found here:
http://morphzone.morphos-files.ppa.pl/categories/utilities/emulation
It works like a charms. Even my USN Joystick works on it!
But what if I want to play with keyboard and do not use the joystick?
Is there any way to configure any keys fore the basic game moves and fire?
No key seem to work in here.
Thanks
09.04.10
14:54
CountRaven
# 2
Problem solved. Changed the config files. The solution is almost always on the documents.
Thanks for looking.
09.04.10
16:38
