Posts: 1397 from 2003/2/15
mz staff: why cant the signature contain images anymore?
First of all, every MorphZone user is free to use a personalized avatar that may contain as many primates as you can fit in the maximum allowed resolution.
You want to have a picture of primates to be part of all of your comments? Good news: You can.
If you would like to know why no images are allowed in the footer of comments, on the other hand, here is a random example picked via a quick web search:
http://www.gamesforum.com/t24084-gamesforum-member-and-forum-awards-09.html
Scroll down and compare the sizes of the images in comment footers to the actual text comments. Frankly, that is neither user-friendly, i.e. it makes the site less easy to read, nor particularly pretty.
While there is a special avatar module that enforces specific size restrictions, the forum software that is used for MorphZone does not actually allow to limit the sizes of images that are part of comment signatures. It just does not work.
So, in order to prevent the misuse of images in signatures as can be seen at the link provided above, there is only one reasonable option in terms of available time and resources. That option is to block images in signatures.
