copying mp3's to ipod touch
    xyphoid
    Posts: 870 from 2008/7/11
    Has anyone done this, or is it that morphos also cant write to the formatted drive?
    What's also strange is I can't access the files on it also.
    [ Edited by xyphoid on 2010/2/27 10:22 ]
  • »27.02.10 - 13:20
    SoundSquare
    Posts: 1214 from 2004/12/1
    the ipdo touch, unlike the classic ipod, can't be used as mass-storage.
  • »27.02.10 - 13:29
    xyphoid
    :-( I guess it's tied to the itunes, what about viewing the files though? I guess that wouldn't be necessary.....
  • »27.02.10 - 13:46
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    You could always jailbreak it and FTP the Mp3s to the correct folders iirc.
    My Macs:
  • »27.02.10 - 14:05
    Posts: 1390 from 2010/1/6
    I'm not sure - but have a look at these progs: http://aminet.net/search?query=ipod
    Maybe IpodDisk can help you. I know, its a AOS4-prog, but perhaps it run on MOS too (with OS4 emu). I have no Ipod, so I can't test it........
  • »27.02.10 - 14:18
    pampers
    Posts: 1073 from 2009/2/26
    I have an old 30GB video edition (5th generation) and I'm using rockbox as a main software for my Ipod so I can easilly upload music on MorphOS. But I'm not sure if there is an Ipod Touch RockBox at all..
    MorphOS 3.x
  • »27.02.10 - 14:49
    clr666
    Posts: 86 from 2008/7/8
    Just copy of mp3's on iPod touch/iPhone not enough - need proper writes in database. Without this mp3's not exist for built-in player. But after jaibreak available much more 3rd party custom players, plays directly from filesystem. And yes, opens many ways for send/receive files via ftp, http, samba, etc.
    _______________
    wintel free
  • »27.02.10 - 16:20
    stephen_robinson
    Posts: 746 from 2007/4/22
    As a matter of intrest, what is the best Mp3 player for Amigaoid OS? Like one you can just drag and drop folders in to play?
    none of this having to use iPlayer or some other such being Apples/AN others MP3 maker's b*tch sort of thing
  • »27.02.10 - 19:40
    SoundSquare
    avoid apple stuff as much as possible, if you want to be free.
    The best mp3 player for me is the Cowon S9, it has audiophile sound quality (the ipod has a very poor sound quality) plays everything (including lossless like FLAC, Ape... and everything about videos, i never convert anything into mine) and is fully mass storage compatible (works in morphOS).
    The downside is that it's not so easy to find, depends in which part of the worl you are, and it's a bit pricey. But quality is above everything i ever tried (and i tried many of them).
  • »27.02.10 - 21:33
    xyphoid
    Its firmware has been updated,so not sure which jailbreak hack to use, if I would at all(it's really wifey's) need something more on ourside
    @soundsquare
    a few that i tried were ok but this is nice
    http://www.bhphotovideo.com/c/product/597722-REG/Cowon_S9_08TB_S9_8GB_MP3_Player.html
    [ Edited by xyphoid on 2010/2/28 1:30 ]
  • »28.02.10 - 04:26
    @stephen_robinson:
    Use AminetRadio or Kaya! ( http://morphos.lukysoft.cz/en/vypis.php?kat=4 )
    Kaya ist part of MOS.
  • »28.02.10 - 05:02
    trotter
    Posts: 106 from 2010/1/14
    I would recommend cowan players as well.
    I have the iaudio D2 which has a sd card slot.
    The S9 is nice but no sd card slot which i use for recent track
    usage since i dont have room for a mp3 player on my pc but can have an sd card sticking out of a card reader :)
    Martin N
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »28.02.10 - 12:32
    Kaya was part of the MOS 1.4x distibution. You can use the distribution for ClassicPPC-Amigas instead......
    The ISO can be loaded from here: http://powerup.morphos-team.net/morphos145pup.iso.lha
  • »28.02.10 - 15:03
    Posts: 2095 from 2003/6/4
    While Cowon is a clever choice, there's another alternative: iRiver.
    They also build fine audio equipment that support many formats. Dunno much about quality of their current devices (the e100 looks nice), but my good old IHP-120 is very reliable since years and worked well with MorphOS from day one (IIRC about 5 years ago).
    I also installed Rockbox as an alternative system on the player (dual boot) and it works nice, too.
  • »28.02.10 - 15:22
    SoundSquare
    @Zylesea
    while the iRiver products are not as good as Cowon (in terms of audio quality i mean), they are very very good products. They were better in the past though (golden age of the SlimX ; ) ) and you IHP-120 was a must have back in time, i always loved this player.
  • »28.02.10 - 16:19
