OpenBSD problems
    Posts: 13 from 2003/2/28
    I want to try out OpenBSD on my Peg, but I can't get past the first hurdle. I burned the CD, and pop it in the drive
    I type
    boot cd:OFWBOOT 3.4/pegasos/bsd.rd
    as instructed, and I get the error
    bootimage is of unknown format
    Anyone know what the problem is?
    Cheers
    Moray
  • »03.11.03 - 16:39
    Posts: 2565 from 2003/2/24
    Try:
    boot /pci/cd OFWBOOT 3.4/pegasos/bsd.rd
  • »03.11.03 - 17:02
    UPDATE:
    Got OpenBSD installed, but it won't boot, it's trying to use wd1a as the root partition, even though I repeatedly told it to use wd0a, I type in wd0a, it panics and crashes.
    Your suggestion led me to try something else
    boot /pci/ide/cd ofwboot
    then it asks for the path
    so I type
    3.4/pegasos/bsd.rd
    and it boots!
    Of course, that's not the end of the story, it appears to install OK, then won't boot, I think my HD is f**ked, as 'disklabel' and 'fdisk' report different partions on the disk. I need to find a way to wipe the disk properly.
    Thanks a lot for the suggestion, I think I was a bit confused about the OpenFirmware error, it suggested the file was corrupted, but I think it just couldn't find it.
    Cheers
    Moray
  • »03.11.03 - 19:31
    If you got PC (with Win), you could use that to wipe the HD ;)
    Or maybe Linux-fdisk.
  • »04.11.03 - 02:18
    bbrv
    Posts: 751 from 2003/2/14
    Hi!
    Start here:
    http://odc.pegasosppc.com
    That is where you should post your question.
    R&B
     :-D
  • »04.11.03 - 09:26
