LaTeX
    Mandy
    Posts: 13 from 2009/11/1
    I want to use LaTeX. Does it work on MorphOS?
  • »10.02.10 - 06:49
    Posts: 12572 from 2003/5/22
    I can't help you with your question. Just refer you to a recent thread about the topic:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6291&forum=9
  • »10.02.10 - 10:13
  • tom
    tom
    Posts: 149 from 2003/7/22
    Well, untill now no succes, I've tried the latex-compiler? in the sdk, but I'm not so experienced so if someone give hints? Untill now I only got reports about everything, but no actual result. . But if you have only tekst you can upload your stuff to:
    http://dev.baywifi.com/latex/Default.aspx
    that will work fine.
    I'm working on a simple editor in Muibase and it works now for only text. (with chapters, etc)
    Regards Tom
  • »10.02.10 - 11:31
  • tom
    tom
    Oke, forgot to call some silly \usepackage.
    Now uploading is working with (simple jpg) graphics
    Fun!!!
    Regards Tom
    (next step will be to use the SDK-package)
    [ Edited by tom on 2010/2/10 18:11 ]
  • »10.02.10 - 14:38
    Mandy
    Thank you so much for your answers, I missed that thread . 8-D
  • »11.02.10 - 16:00
