MPLAYER option?-correct-pts (EXPERIMENTAL) ?
    osco
    Posts: 680 from 2009/10/21
    Switches MPlayer to an experimental mode where timestamps for
    video frames are calculated differently and video filters which
    add new frames or modify timestamps of existing ones are supâ?‚?
    ported. The more accurate timestamps can be visible for example
    when playing subtitles timed to scene changes with the -ass opâ?‚?
    tion. Without -correct-pts the subtitle timing will typically
    be off by some frames. This option does not work correctly with
    some demuxers and codecs.
    Time shown on Dispay (GMPlayer) is not that accurate? Have any tried this option?
    Is WMV supported?
  • »08.02.10 - 18:02
