Posts: 454 from 2006/11/16
I got a an amiga600 with internal CF as harddrive.
Formatted in two a boot and extra partition.
The boot is offcourse the workbench partition while the extra is for all programs I would like to use,try out.
I put this CF card intyo my peg2 and one partition shows up ..the extra .
Not a problem I thought and moved some files from aminet cd's etc to this partition and reinstalled it into the amiga600.
I then tried to run some off these progams..recoverable errors, software failures etc..
This happens with all programs I transfer this way but not for programs I moved from the boot partition to the extra partition on the amiga600 .
Example If I copy the shell from boot to the extra no problem.
Any tips?
