System freezes opening PDF file?
    osco
    Posts: 680 from 2009/10/20
    Any suggestions?
    TIA
  • »25.01.10 - 19:08
    mihailod
    Posts: 170 from 2010/1/8
    Can you be more specific?
    Does it freeze every time on every PDF? Sporadically? On a specific PDF file? If so, can you open that file on another machine with another PDF viewer (or another PDF viewer on MorphOS)? Can you save it on another drive and try from there? Can you copy file to another destination and see if it is corrupted?
    (DISCLAIMER: I don't know much about PDF handling on MorphOS -- haven't got to that yet, those questions above are just basic QA 101 stuff.)
  • »25.01.10 - 19:43
    kickstart
    Posts: 227 from 2009/4/28
    macminis hace 32 or 64 gfx memory, if is a big pdf and you have some other programs running maybe the slowdowns can be caused by a low chip memory (imho).
  • »25.01.10 - 21:06
    osco
    [1] [ramlib] [Open] [MOSSYS:LIBS/mui/Popmenu.mui.elf] [Read] [Fail]
    [2] [ramlib] [Open] [MOSSYS:LIBS/mui/Popmenu.mui.elf] [Read] [Fail]
    [3] [ramlib] [Load] [MOSSYS:LIBS/mui/Popmenu.mui.elf] [] [Fail]
    [4] [ramlib] [Open] [MOSSYS:LIBS/mui/Popmenu.mui] [Read] [Fail]
    [5] [ramlib] [Open] [MOSSYS:LIBS/mui/Popmenu.mui] [Read] [Fail]
    [6] [ramlib] [Load] [MOSSYS:LIBS/mui/Popmenu.mui] [] [Fail]
    [7] [ramlib] [Open] [LIBS:mui/Popmenu.mui.elf] [Read] [Fail]
    [8] [ramlib] [Open] [LIBS:mui/Popmenu.mui.elf] [Read] [Fail]
    [9] [ramlib] [Load] [LIBS:mui/Popmenu.mui.elf] [] [Fail]
    [10] [ramlib] [Open] [mui/Popmenu.mui.elf] [Read] [Fail]
    [11] [ramlib] [Open] [mui/Popmenu.mui.elf] [Read] [Fail]
    [12] [ramlib] [Load] [mui/Popmenu.mui.elf] [] [Fail]
    [13] [ramlib] [Open] [muidebug] [Read] [Fail]
    Not a clue whats happening?
  • »25.01.10 - 22:33
    osco
    I was in a Ambient shell..I was inputing shell commands to see the output. I typed cli and a new shell window appeared.
    I needed 9 shell windows so I typed cli eight more times. I ran mmsclient in these shells... THE SHELL WINDOW was a MORPHOS shell window...did I do a "no no" ????
  • »25.01.10 - 22:41
    osco
    Snoopium log showed ADPF tooltype failing? :-D
  • »25.01.10 - 22:51
    osco
    Ran Snoopium failures everywhere? Time to back up all data files :(
  • »25.01.10 - 23:05
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    These "failures" are just normal. The library system first checks for <library>+<.elf> for historical reasons. If it's not found, then it tries again with the <library> one. And there are several paths to be looked for, too. Then a program can also check for some env variables to adjust its behaviour, and these variables may not exist, hence a fail in Snoopium.
    So don't see a problem where there isn't. A fail in snoopium/snoopdos doesn't necessarily mean there is actually an issue, far from it.
    [ Edited by Fab on 2010/1/26 13:02 ]
  • »26.01.10 - 10:59
    kriz
    Posts: 312 from 2005/10/18
    yep, dont over-analyze the data.
  • »26.01.10 - 11:29
    osco
    I think the pdf were in a self destruct mode. I deleted the lot.
    Onward....but it is time to back up :-D
  • »26.01.10 - 12:56
    Posts: 12530 from 2003/5/22
    Doesn't sound like making any sense at all. You're too confused :-P
  • »26.01.10 - 21:46
