mp3 to amiga format
    amiga4001
    Posts: 454 from 2006/11/16
    I want to record some mp3 sounds like a woodsaw in progress,a hammer etc...
    These mp3 's I want to convert to an amiga friendly soundfile.
    It want to play them on an amiga600 no pimped up one just a simple 68000 cpu.
    Any tips on the kind off format to use?
    And a tip for a converterprogram which will work on MOS?
    And maybe a tip for a nice simple player for the amiga600.
  • »21.01.10 - 17:34
    Samurai_Crow
    Posts: 198 from 2009/12/10
    http://aminet.net/package/mus/play/Play16 is a good player for a classic Amiga. You'll probably want to use an IFF format for your sample such as AIFF for 16-bit samples due to Amiga being a big endian system. If you don't mind an 8-bit sample then IFF-8SVX would be a better choice. When playing 16-bit samples they only get the top 14-bits of precision due to hardware limitations.
  • »21.01.10 - 18:12
    amiga4001
    Don't mind the lower quality i'll go for the iff-8SVX format then.
    But is there a converter from mp3 to iff-8svx?
    Think I found something: http://aminet.net/package/mus/edit/Samplemanager
    Reads mp3 and can convert to 8svx
    [ Edited by amiga4001 on 2010/1/21 20:23 ]
  • »21.01.10 - 18:20
    Posts: 12500 from 2003/5/22
    Swiss Army knife of sound processing programs:
    http://aminet.net/package/mus/edit/sox-morphos
    Most recent version:
    http://www.hd-rec.de/Archive/Samplemanager.lha
  • »22.01.10 - 04:00
    Matt_H
    Posts: 30 from 2009/2/21
    @ amiga4001
    I've used this with much success. Shell-based. Very lightweight and quick.
  • »22.01.10 - 14:36
