Posts: 680 from 2009/10/20
System:Applications/MPlayer-1.0/MPlayer-1.0-svn-2009.08.30> MPlayerOutput below
MPlayer SVN-r29543-4.2.4 (C) 2000-2009 MPlayer Team
138 audio & 300 video codecs
Usage: mplayer [options] [url|path/]filename
Basic options: (complete list in the man page)
-vo <drv> select video output driver ('-vo help' for a list)
-ao <drv> select audio output driver ('-ao help' for a list)
dvd://<titleno> play DVD title from device instead of plain file
-alang/-slang select DVD audio/subtitle language (by 2-char country code)
-ss <position> seek to given (seconds or hh:mm:ss) position
-nosound do not play sound
-fs fullscreen playback (or -vm, -zoom, details in the man page)
-x <x> -y <y> set display resolution (for use with -vm or -zoom)
-sub <file> specify subtitle file to use (also see -subfps, -subdelay)
-playlist <file> specify playlist file
-vid x -aid y select video (x) and audio (y) stream to play
-fps x -srate y change video (x fps) and audio (y Hz) rate
-pp <quality> enable postprocessing filter (details in the man page)
-framedrop enable frame dropping (for slow machines)
Basic keys: (complete list in the man page, also check input.conf)
<- or -> seek backward/forward 10 seconds
down or up seek backward/forward 1 minute
pgdown or pgup seek backward/forward 10 minutes
< or > step backward/forward in playlist
p or SPACE pause movie (press any key to continue)
q or ESC stop playing and quit program
+ or - adjust audio delay by +/- 0.1 second
o cycle OSD mode: none / seekbar / seekbar + timer
* or / increase or decrease PCM volume
x or z adjust subtitle delay by +/- 0.1 second
r or t adjust subtitle position up/down, also see -vf expand
* * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * *
Command Below
System:Applications/MPlayer-1.0/MPlayer-1.0-svn-2009.08.30> MPlayer- mms://66.209.93.118/Replays2010/201001141504TAM7.wmv?CUST=TampaBay&TICKET=09a51fa3be90b47dfbd79c0e4c303ff4%7C1263502002%7C300%7C%2A%7CTampaBay%7C1000%7C0%7C0\
MPlayer-: Unknown command
System:Applications/MPlayer-1.0/MPlayer-1.0-svn-2009.08.30> MPlayer-mms://66.209.93.118/Replays2010/201001141504TAM7.wmv?CUST=TampaBay&TICKET=09a51fa3be90b47dfbd79c0e4c303ff4%7C1263502002%7C300%7C%2A%7CTampaBay%7C1000%7C0%7C0\
MPlayer-mms://66.209.93.118/Replays2010/201001141504TAM7.wmv?CUST: Unknown command
A requester opened
"Shell Process"
Please insert volume
MPlayer-mms
in any drive
Retry Assign Mount Deny Cancel
Steep learning curve here?
