FryingPan issues...
    Travis_H
    Posts: 165 from 2009/12/17
    I just registered FryingPan and have come across a couple oddities:
    1. Sometimes FryingPan will simply refuse to write a disc when I press 'Write.' This is on a MacMini. I found (it worked better at least once) to pull the files from a source other than the harddrive (USB, RAM). Maybe the MacMini's IDE bus isn't smart enough to handle HD access and CD-R burning.
    2. The online manual is out of date: Can someone tell me how to change the name of the disc from CD-ROM to something more descriptive? What does the button "Masterize CD" mean?
    3. FryingPan works flawlessly on Amithlon.
    TJH
  • »11.01.10 - 22:04
    Posts: 12543 from 2003/5/22
    Probably related to that:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6798&forum=11
  • »11.01.10 - 22:20
    Travis_H
    Yes, I read that thread first and wondered if it was related to my problem. Using a USB harddrive seemed to fix the problem (but I've only tested it with one CD-R, and it worked).
    TJH
  • »11.01.10 - 22:27
    MarK
    Posts: 641 from 2004/1/25
    to change the burning disc name can be made by clicking on the bottom right (popup) button, and on the second page (of the popped window) :)
    bye, MarK.
  • »12.01.10 - 04:07
    dake
    Posts: 204 from 2007/9/14
    I didnt have any problem when writing the data, the problem where actually when finalization the disk.
    [ Edited by dake on 2010/1/12 12:22 ]
  • »12.01.10 - 09:18
    Travis_H
    Thanks for the tip! I thought I'd clicked on every gadget in the GUI before asking the question. Even after your answer, I had to look twice to find it!
    Thanks again,
    TJH
  • »12.01.10 - 19:14
