Posts: 154 from 2003/4/22
>I plan to buy a pegasos next spring and I'd like to ask something.
Good idea !
>How stable is Morphos compared to mainstream OSes like win9x
>(or even win 2000/XP)?
MorphOS is stable.
More than Win9x/ME but not as robust as WinXP or Linux.
>What happens if you ran an application that's
>badly written? Does the whole OS crash and you have to restart?
Well, it depends how bad the application crash.
If it "only" write to 0, it should not be nasty. But if it traches the
exec structure then you are dead
>Or you close the application and everything is fine?
I advice to "hide" the application's window, but don't try to remove it.
>Is momory protection already implemented or this is planned for a future release?
Well, it's but not in the ABox. And the ABox is thes space where
all current software are running, so in a user point of view, no
memory protection for now. The QBox will solve that pb in the future.
The goal of the ABox is to provide an "AmigaOS" like environement
for the application. nevertheless, it doesn't allow clean/proper
memory protection
>Wouldn't it be nice if Altivitec was supported by the gfx card drivers?
I don't know maybe.
However, other part of the OS (may gain more) like bitmap processing or CopyMem might
be optimize for Altivec. But I really don't know !
>I know, the power of pegasos is already more than enough for existing
>apps but it would be better if we could get 100% out of the system.
What do you mean ? MorphOS is not fast enough ?
>Why Genesi don't intend to support the onboard floppy drive on MOS?
Well, I don't think it will ever be done. There is so much stuff
to do before (as I see) and a floppt drive is quiet obsolete.
However, if you really want one, you can buy an USB one. Should work
under MorphOS.
About MP, it's only needed because of bad application, then don't use it!
Ok, sometimes we don't have the choice !!
Bye
MorphOS Rulez !
