MPlayer video choppy audio ok?
    osco
    Posts: 680 from 2009/10/20
    mms://66.209.93.118/Replays2009/200912301412TAM5.wmv?CUST=TampaBay&TICKET=9e5a5f11b1a787bcb2e1510d041a3256%7C1262203167%7C300%7C%2A%7CTampaBay%7C1000%7C0%7C0
    Its a race replay.. Is it Bad Net Connection, Mplayer, Or can Mplayer be tweeked to improve play?
    Stream to be recorded but failed? Ram;stream.dump? :-(
  • »30.12.09 - 18:06
    boot_wb
    Posts: 874 from 2007/4/9
    Unable to access to check using Firefox on XP with VLC or WMP. Probably requires authentication at some point.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »30.12.09 - 18:17
    osco
    MorphOS and MPlayer access the library. The autherization is in the mms address..Is it the net,
    library, Mplayer, or prefs/ or all?
    TIA
  • »30.12.09 - 18:29
    osco
    Clicking the link in OWB will return a PROTOCALL error.But a manual copy and paste into MPayer connects to the library. Its what happens after that is an issue/
    MPlayer has many options and settings :)
    [ Edited by osco on 2009/12/30 15:35 ]
  • »30.12.09 - 18:33
