Posts: 1397 from 2003/2/15
@ SixK
OK I see the problem with my port, It seem's I only put the binary... You may find a complete archive for another target and use my binary.
Well, I obviously noticed that it was just a binary. I copied it into an older port of yours (1.31 or so). But no change.
If you took the good one and php don't work, maybe php support have not been activated in config file. You will have to read the (fucking) Manual ;)
If you check the archive on AmiNet, you will notice that, while multiple text files are included, there is literally no useful documentation included. Just some to-do list and basic information about how wonderful thttpd is. I read it all yesterday (not much there to begin with) but did not find any clues whatsoever.
(In php.ini, the PHP engine is switched on at least.)
Edit: Hmmm. thttpd actually works now. Loading pages from disk is a tad slower than I maybe expected though :) Anyway, thanks again for the hint regarding thttpd.
