Question about SabreMSN
    metalmac
    Posts: 87 from 2007/5/26
    Hi!
    I have a problame with SabreMSN, it starts up and everything but when I try to conect it fails, is there somthing I have to do to get it conected?
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »02.12.09 - 16:49
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    version 0.59 ?
    be sure you have entered password correctly : since 0.50, password is case sensitive.
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »02.12.09 - 16:59
    BurnTwice
    Posts: 38 from 2009/10/27
    Sorry for abusing this thread. At least, I also have a question about SabreMSN. ;-)
    How do I make the smiley-symbols show up? It seems there has to be a set of smiley installed since the smiley folder is empty (except for two). If so (and Sabre supports smileys at all), where can they be downloaded? Or copied from original MSN?
    [ Edited by BurnTwice on 2009/12/2 21:04 ]
  • »02.12.09 - 20:01
  • szt
    szt
    Posts: 53 from 2004/10/9
    You can download the smileys from the SabreMSN homepage:
    http://wookiechat.amigarevolution.com/sabremsn/24bit_IFF_ILBM_smileys.lha
    MorphOS 3.9
    PowerMac 7,3, 1,8GHz,
    Radeon 9600
    300 GB SeagateHDD, 120 GB Samsung SSD
    LGM2382D, Canon MG7550
  • »02.12.09 - 20:50
    BurnTwice
    @ szt
    Thank you!
    Somehow I always missed the link, when I was on that page...
    Maybe it was always too late or some beers too many ;-)
  • »02.12.09 - 21:03
    Jambalah
    Posts: 820 from 2008/3/30
    @ Metalmac:
    Try to upgrade your codeset library. I had the same problem and I couldn't understand how to solve it. I was opening YAM that adviced me about a new version of this library. I upgraded it and after a couple of days I tried SabreMSN, trying to understand why it didn't work.. And all went ok!
    You find the lib here:
    codeset.library
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »02.12.09 - 21:06
    metalmac
    Thansks!
    I have version 0.60, will try the codeset.library.
  • »03.12.09 - 02:54
    metalmac
    I have now tried to replace the codeset.library that I had in my Libs folder, but it still not conect? :-(
  • »03.12.09 - 14:16
    Jambalah
    Did you check if something else is missing?
    Betterstring.mcc, NList.mcc and AmiSSL..?
    Pegasos II 1 ghz
  • »03.12.09 - 14:32
    metalmac
    Yes, I have them, and the program is not telling me that anything missing?
  • »03.12.09 - 15:30
    Jambalah
    Yes... you are right... Stupid question from me!
    So.. :-?
    I tried to launch sabre msn with snoopium active and nothing particular when program start (graphics, AmiSSL, and so on..).
    I cannot tell you.. Did you try to connect more after the first attempt failed?
    I remember I did a lot of things: erase everything and installed again, downloaded an old version to see if it worked (and it did..), tried with another account. I thought was the codeset.library... maybe MSN itself, did some change?!?
    Pegasos II 1 ghz
  • »04.12.09 - 12:17
