Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
ending mldonkey
amiga4001
# 1
Posts: 452 from 2006/11/16
I forgot how to end the muicon window.
Something with ctrl or alt?
03.12.09
18:51
dake
# 2
Posts: 204 from 2007/9/14
You can end MLDonkey with ctrl c in the MUICon window or use the Taskmanager and end the task named "Background CLI [mlnet]".
03.12.09
19:18
tom
# 3
Posts: 148 from 2003/7/22
Or click on 'kill MLDonkey' in your browser.....
(http://localhost:4080/)
cheers, Tom
03.12.09
19:45
Mi-Go
# 4
Posts: 95 from 2003/9/18
...or by issuing a "KILL" command from telnet
04.12.09
05:11
