[morphos 2.4] bug with apdf 3.4
    SoundSquare
    Posts: 1213 from 2004/12/1
    I just discovered a bug with apdf. I downloaded and opened a pdf (old seagate scsi drive manual) and it displayed fine in apdf. When clicking the "Zoom" gadget, and selecting "0" i get MorphOS to freeze. Nothing to do but a cold reboot.
    I tried 3 times and it froze all 3 times. Could someone confirm this bug so i can be sure it doesn't come from my setup ?
    i uploaded the pdf i was reading here : http://soundsquare.free.fr/morphos/100195486a.pdf
    so you can check the bug in the same conditions.
  • »02.12.09 - 19:55
    AKiLL
    Posts: 91 from 2006/3/6
    Probably the problem is in your setup!
    Here Apdf 3.4 correctly open and zoom your linked file.
    The only problem occurred just using previous Apdf version was an annoying system slowdown in a few seconds after exiting program.
    Bye,
    AKiLL
  • »02.12.09 - 20:40
    SoundSquare
    thanks for your test AKiLL (and your time), i'll investigate on my side then.
  • »02.12.09 - 21:06
