snes9x freezing with black screen
    Caius
    Posts: 7 from 2009/11/14
    I'm having problems getting the snes9x by Fab working. All I get is a black screen, and nothing else happens. If I run in windowed mode, the window's title bar says that the program is meditating. I've tried switching various options like audio emulation. Using snes9xstarter. The roms are smc files, and they work with znes in the PC. Hmm, what else. Oh yeah, I get a message in a console window saying "No ROM file header found."
    Using Mac Mini and MorphOS 2.4.
    Any ideas?
    [ Edited by Caius on 2009/11/30 8:49 ]
    Theology is just a debate over who to frame for creating reality.
  • »30.11.09 - 07:48
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    No idea. I just tested it on mac mini, and it works just perfectly.
    Which archive did you download? How do you use it? Any debuglog?
  • »30.11.09 - 12:14
    Caius
    Hmm. Seems like the roms I used simply don't work with snes9x, because I located different ones which works. In short, everything works great now :-)
  • »30.11.09 - 13:52
