Milkytracker issues unde mos 2.4
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello, i have been trying to use milkytracker for mod playing because hivelytracker only plays .ahx files.
    The thing is that milkytracker loads well, but when i try to load a file, the app freeze.?If i try to close the window, ambient tells me that the application is dead and stay an open shell.
    I have tried both doubleclicking the icon, as well as using os4emu via command line. I have the setpatch and the installation files where it should be.
    Anyone can point me to the solution?
    Thanks in advance!
  • »23.11.09 - 17:10
  • mok
    Posts: 1 from 2009/11/23
    I managed to get my pro track mods running. i beleive the bug is related to invalid default load paths.
    what i did is move the app to the directory of my modules file & add the shorcut to my panel & when i click on the load button i then immediately click on the home button & that will show the list of the directory where your running the app from i.e. my modules dir. after it loads it works flawlessly..
  • »23.11.09 - 19:30
    Korni
    Posts: 473 from 2006/2/23
    There are several PT (and other) MOD players available on MorphOS. I use UADE myself http://morphos-files.net/find.php?find=uade. Trackers are for composing tunes not only for playing them, especially if a program doesn't work well like MilkyTracker.
    [ Edited by Korni on 2009/11/23 23:26 ]
  • »23.11.09 - 21:20
  • HAK
    Posts: 227 from 2003/2/24
    Well, I'm only using MilkyTracker as a player - as I'm no composer, but until now I didn't have any problems with it.
    @ _ThEcRoW:
    What do you need os4emu for? The MilkyTracker I have is a nativ MorphOS version - IIRC it needs powersdl though.
    Bye HAK
  • »23.11.09 - 21:52
    _ThEcRoW
    Well, i needed a program that allowed me to play .mod files, and, since milky can play them i thought of giving it a try since os4emu is available on mos. I?heard of people runing the app with no problem so i gave it a go. Eventually i found a player that plays mods perfectly, but still want to run milky because the visual thing :). I always liked trackers for playing since mu early days on my 500 and pc boxes.
    P.D: I didn't know there was a native mos versio. WHere to download it?
    P.D: Is additional software neccesary?
    [ Edited by _ThEcRoW on 2009/11/24 9:28 ]
  • »24.11.09 - 08:26
    Ruud
    Posts: 335 from 2009/2/2
    This any good?
  • »24.11.09 - 09:12
    _ThEcRoW
    ok, installed and running perfectly. Is a direct port of os4 milky?, i mean, is there any difference between versions?
    Thanks for the link!!!
    P.D: Is the milkytracker page online. I cannot load it up.
    P.D: The error i got with os4emu, what could be the cause?
  • »24.11.09 - 09:40
    Posts: 12564 from 2003/5/22
    It's a direct "port" of SDL Milkytracker.
    Just compare version numbers and release dates.
    http://www.downforeveryoneorjustme.com/milkytracker.net
  • »24.11.09 - 09:52
