Text editor "a comfortable font setting to work with?"
    osco
    Posts: 680 from 2009/10/20
    In a cave but with a small pen light :)
    It's been awhile but scripting has started again..
    I am now setting up the environment and am curious what font and size
    coders use? :-P
  • »21.11.09 - 06:04
    Krashan
    Posts: 1107 from 2003/6/11
    I use 1024 x 768 resolution at home and 1280 x 1024 at work. As the pixel size on my monitors is almost the same, I use the same fonts for text editing (which includes programming of course). I have two favourites (both are of course monospaced). Both are made by me, by converting TrueType fonts to bitmaps and handtuning them in Typeface (a bitmap font editor).
    Font, which I use most is Courier at 13 pixels (screenshot).
    The second one is sans-serif: DejaVuSansMono at 14 pixels (screenshot). This one is my system fixedwidth font (used in shell windows). As I like serif fonts, Courier is my first choice in my programmer editor.
  • »21.11.09 - 09:53
    osco
    Ty, The Courier seems a better choice. It's a bit crisper and easier to follow.
    I have CED 3.5 now and saw you had a higher version.  :-o
    Will be using Reggai with legacy graphics applications.
    Laters
    osco
  • »21.11.09 - 11:41
    Krashan
    Here.
  • »21.11.09 - 12:42
    Posts: 12572 from 2003/5/22
    > Here.
    I think he knows already ;-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6655&forum=9#67769
  • »22.11.09 - 15:36
    osco
    Ty Ktashan for the link and your help. I think I'll be at ALL of your links :-)
  • »22.11.09 - 16:17
    MarK
    Posts: 641 from 2004/1/25
    i use e.font size 11 and end.font size 11, these are also great for programming (perhaps could be somewhere on the aminet in some amigae archive).
    bye, MarK.
  • »23.11.09 - 11:52
