Can't open MUI settings anymore
  • rms
    rms
    Posts: 606 from 2004/11/27
    I have a problem, suddenly I can't open the MUI settings anymore and I get the following error:
    21-Nov-09 17:15:26
    68k Exception 11 <LineF>
    Task 0x2638A650 <MUI>
    Dn[0] 00000010 1029e580 2004ef6c 263a18d4 263ce5e3 2638a6ac 263a18d0 263a1880
    An[0] 263a1750 200bbb80 098ec8ac 263d0000 263b0000 263d6e00 20001948 2638e72c
    PC 5c34200f SR 0004
    PPC StackTrace:
    [ 0] 0x10114700 -> <@ABox: Module> Hunk 0 Offset 0x14700
    [ 1] 0x10114158 -> <@ABox: Module> Hunk 0 Offset 0x14158
    [ 2] 0x1011dbf8 -> <@ABox: Module> Hunk 0 Offset 0x1dbf8
    [ 3] 0x228d9d6c -> <@MOSSYS:LIBS/trance.library> Hunk 1 Offset 0x20e4
    [ 4] 0x1100738c -> <@ABox: Emulation> Hunk 0 Offset 0x738c
    [ 5] 0x11008aec -> <@ABox: Emulation> Hunk 0 Offset 0x8aec
    [ 6] 0x263b6328 -> <@LIBS:mui/Settings.mui> Hunk 1 Offset 0x33d8
    [ 7] 0x263b6260 -> <@LIBS:mui/Settings.mui> Hunk 1 Offset 0x3310
    [ 8] 0x263b668c -> <@LIBS:mui/Settings.mui> Hunk 1 Offset 0x373c
    [ 9] 0x263b6828 -> <@LIBS:mui/Settings.mui> Hunk 1 Offset 0x38d8
    and here is de ramdebug log:
    Quark Thread:
    TID 0000000010020010
    Name ABox
     Exception 3 <Illegal Data Access at ffff87a2 DSISR 40000000, Load from a not existing Page>
    SRR0 0x11281344 SRR1 0x0200f030
    LR 0x1100738c CTR 0x1128132c
    CR 0x48002085 XER 0x00000000
    GPR[00] 1128132c 263a17d0 263a1850 0000b3e0 00000000 00000004 11008a3c 11008a48
    GPR[08] 110087c0 ffff87a2 74000000 2f736b69 48002285 5c34200f 00000000 1132b824
    GPR[16] 00000100 098ec8ac 263b21a4 00000100 098ec867 fffffffe 20023960 00000074
    GPR[24] 2638a6ae 00000000 263a1620 263b28f0 263a49d8 263a4918 2f736b6d 2638e72c
     FPSCR 43efff0000104050
    FPR[00] 0000000010020010 6970726566732032 302e363930322028 31392e30332e3039
    FPR[04] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[08] 3fd999999999999a 3fe4000000000000 4046000000000000 4330000080000000
    FPR[12] 404a800000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    VSAVE 00000000
    VSCR 00010000
    VPR[00] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[02] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[04] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[06] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[12] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[14] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[16] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[18] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[20] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[22] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[24] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[26] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[28] 00000000000000000000000000000000 00000000000000000000000000000000
    VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
    IABR 00000000
    DABR 00000000
    MMCR0 00000000
    MMCR1 00000000
    MMCR2 00000000
    PMC1 00000000 PMC2 00000000 PMC3 00000000 PMC4 00000000
    SIA 00000000
    SDA 00000000
    PPCStackFrame History:
    StackFrame[ 0].LR-> Address 0x11008aec -> Emulation Hunk 0 Offset 0x00008aec
    StackFrame[ 1].LR-> Address 0x263b6328 -> LIBS:mui/Settings.mui Hunk 1 Offset 0x000033d8
    StackFrame[ 2].LR-> Address 0x263b6260 -> LIBS:mui/Settings.mui Hunk 1 Offset 0x00003310
    StackFrame[ 3].LR-> Address 0x263b668c -> LIBS:mui/Settings.mui Hunk 1 Offset 0x0000373c
    Strange is, that MorphOS seems to work just fine unless I try to open the MUI settings.
    Any idea?
    Regards
    Christoph
  • »21.11.09 - 14:15
    Posts: 3326 from 2003/3/5
    Sure you didn't place some 68k settings.mui somewhere in the libs: path ?
  • »21.11.09 - 17:29
  • rms
    rms
    Not shure what you mean excately, but I didn't replace change any files in MOSSYS, neither was the settings.mui changed/replaced. It's the one which comes with MorphOS 2.4.
  • »23.11.09 - 02:51
    If you are really sure about that, then it must be some 68k .mcp file you installed recently, because the crash is in 68k emulated code. Sadly, the log does not say which one it is.
  • »23.11.09 - 06:27
