Frying Pan 1.2?
    AyoS
    Posts: 410 from 2003/8/13
    Can the demo version of frying Pan burn a cd?
    I tried and although the CD looks fine the data/music is
    empty after 15 seconds on the first track. I thought the Demo
    would allow you to burn a few MBs? Or is it just my Samsung DVD Burner
    that is the problem?
    I only ask as I am willing to pay for it, but only if it
    works on my current setup. Is it just me or is this the normal reaction of
    the demo? Should I buy another DVD/CDROM Burner?
    Also... has anyone Registered this product recently?
    Any suggestions?
    Thanks,
  • »30.11.08 - 10:33
    Posts: 1087 from 2003/3/24
    Afair in the Demo you can't burn anything with TFP.
  • »30.11.08 - 11:11
    AyoS
    Thanks... I just thought it was me. Do You normally use
    Frying Pan?
  • »30.11.08 - 12:30
    Cego
    Posts: 738 from 2006/5/27
    FryingPan is an excellent piece of software, i use it from time to time (for backups) and its working without any problems here.
  • »30.11.08 - 13:36
    Faranheit
    Posts: 1 from 2008/11/30
    Hi Katos ;)
    The demo version of FP allows you to burn anything you want but as it is a demo, the software corrupts the data while burning.
    This software is really worth it ;)
    Works just fine on MorphOS and AOS4.x ans AOS3.x ;)
    Faranheit ;)
    I.M.M. Informatique
    YOUR Efika reseller for France / Belgium and Luxembourg
    Site : http://informatique-imm.lu/catalogue
    Mail : laurentz@informatique-imm.lu
  • »30.11.08 - 15:21
    AyoS
    Thanks Faranheit and Cego,
    I really like the interface, and it looks like a quality
    product. I will buy it.
  • »30.11.08 - 17:02
    mobydick
    Posts: 179 from 2004/2/26
    AFAIK the latest version is 1.3.3... or 1.3.2?..
    ...1.3.2.
    Do not forget to check CDs for corrupted files.
    [ Edited by mobydick on 2008/12/1 12:01 ]
    peguser.narod.ru
  • »01.12.08 - 06:55
    I use TFP twice a week to burn DVD, DVD-RW and sometimes DVD-DL and ofcourse CD/CDRW and it works great no problems to burn my date on DVD/CD.
  • »01.12.08 - 07:29
    AyoS
    Yes... 1.3.2 not 1.2.3. A little dyslexic on my part.
    the latest demo was the one I was trying.
    Thanks
  • »01.12.08 - 10:01
    mobydick
    May be, I have bad luck... or too old DVD-reader/CD-writer :) Anyway, I prefer to check results.
    peguser.narod.ru
  • »01.12.08 - 18:10
    AyoS
    I was able to use MakeCD with My Samsung Drive
    so I should have no problems with Frying Pan, as it
    recognized my drive and burned with no problems... I just
    didn't realize that It would burn blank tracks.
  • »02.12.08 - 19:44
    xyphoid
    Posts: 870 from 2008/7/11
    I have an issue with FP hanging my mini with a cd mounted. It is also not registering the program, and I placed the keyfile in the following areas L: S: Devs: all the places it should go, including MOSSYS. Can anyone help. I coundn't find the thread on this, I know it existed somewhere.
  • »21.11.09 - 22:21
    Ruud
    Posts: 335 from 2009/2/2
    I was testing the demo on my mini and it hangs the system with a CD in the drive here too :-(
  • »22.11.09 - 08:42
    xyphoid
    Tomek said
    "I just installed your key on my machine and it started working immediately (L:).
    1) check whether morphos left protection bits R and E (so at least R-E-) applied for optical.key,
    2) please send me snoop dos log that covers program launch after reset if the above doesn't work."
    Not sure what he means(1), so I posted the snoop
    [1] [ramlib] [Open] [MOSSYS:LIBS/mui.interface.elf] [Read] [Fail]
    [2] [ramlib] [Open] [MOSSYS:LIBS/mui.interface.elf] [Read] [Fail]
    [3] [ramlib] [Load] [MOSSYS:LIBS/mui.interface.elf] [] [Fail]
    [4] [ramlib] [Open] [MOSSYS:LIBS/mui.interface] [Read] [Fail]
    [5] [ramlib] [Open] [MOSSYS:LIBS/mui.interface] [Read] [Fail]
    [6] [ramlib] [Load] [MOSSYS:LIBS/mui.interface] [] [Fail]
    [7] [ramlib] [Open] [LIBS:mui.interface.elf] [Read] [Fail]
    [8] [ramlib] [Open] [LIBS:mui.interface.elf] [Read] [Fail]
    [9] [ramlib] [Load] [LIBS:mui.interface.elf] [] [Fail]
    [10] [ramlib] [Open] [mui.interface.elf] [Read] [Fail]
    [11] [ramlib] [Open] [mui.interface.elf] [Read] [Fail]
    [12] [ramlib] [Load] [mui.interface.elf] [] [Fail]
    [13] [ramlib] [Open] [MOSSYS:LIBS/fryingpan.engine.elf] [Read] [Fail]
    [14] [ramlib] [Open] [MOSSYS:LIBS/fryingpan.engine.elf] [Read] [Fail]
    [15] [ramlib] [Load] [MOSSYS:LIBS/fryingpan.engine.elf] [] [Fail]
    [16] [ramlib] [Open] [MOSSYS:LIBS/fryingpan.engine] [Read] [Fail]
    [17] [ramlib] [Open] [MOSSYS:LIBS/fryingpan.engine] [Read] [Fail]
    [18] [ramlib] [Load] [MOSSYS:LIBS/fryingpan.engine] [] [Fail]
    [19] [ramlib] [Open] [LIBS:fryingpan.engine.elf] [Read] [Fail]
    [20] [ramlib] [Open] [LIBS:fryingpan.engine.elf] [Read] [Fail]
    [21] [ramlib] [Load] [LIBS:fryingpan.engine.elf] [] [Fail]
    [22] [ramlib] [Open] [fryingpan.engine.elf] [Read] [Fail]
    [23] [ramlib] [Open] [fryingpan.engine.elf] [Read] [Fail]
    [24] [ramlib] [Load] [fryingpan.engine.elf] [] [Fail]
    [25] [ramlib] [Open] [MOSSYS:LIBS/Optical.elf] [Read] [Fail]
    [26] [ramlib] [Open] [MOSSYS:LIBS/Optical.elf] [Read] [Fail]
    [27] [ramlib] [Load] [MOSSYS:LIBS/Optical.elf] [] [Fail]
    [28] [ramlib] [Open] [MOSSYS:LIBS/Optical] [Read] [Fail]
    [29] [ramlib] [Open] [MOSSYS:LIBS/Optical] [Read] [Fail]
    [30] [ramlib] [Load] [MOSSYS:LIBS/Optical] [] [Fail]
    [31] [ramlib] [Open] [LIBS:Optical.elf] [Read] [Fail]
    [32] [ramlib] [Open] [LIBS:Optical.elf] [Read] [Fail]
    [33] [ramlib] [Load] [LIBS:Optical.elf] [] [Fail]
    [34] [ramlib] [Open] [Optical.elf] [Read] [Fail]
    [35] [ramlib] [Open] [Optical.elf] [Read] [Fail]
    [36] [ramlib] [Load] [Optical.elf] [] [Fail]
    [37] [ramlib] [Open] [MOSSYS:LIBS/expat2.library.elf] [Read] [Fail]
    [38] [ramlib] [Open] [MOSSYS:LIBS/expat2.library.elf] [Read] [Fail]
    [39] [ramlib] [Load] [MOSSYS:LIBS/expat2.library.elf] [] [Fail]
    [40] [ramlib] [Open] [MOSSYS:LIBS/expat2.library] [Read] [Fail]
    [41] [ramlib] [Open] [MOSSYS:LIBS/expat2.library] [Read] [Fail]
    [42] [ramlib] [Load] [MOSSYS:LIBS/expat2.library] [] [Fail]
    [43] [ramlib] [Open] [LIBS:expat2.library.elf] [Read] [Fail]
    [44] [ramlib] [Open] [LIBS:expat2.library.elf] [Read] [Fail]
    [45] [ramlib] [Load] [LIBS:expat2.library.elf] [] [Fail]
    [46] [ramlib] [Open] [expat2.library.elf] [Read] [Fail]
    [47] [ramlib] [Open] [expat2.library.elf] [Read] [Fail]
    [48] [ramlib] [Load] [expat2.library.elf] [] [Fail]
    [49] [ramlib] [Open] [MOSSYS:LIBS/isobuilder.module.elf] [Read] [Fail]
    [50] [ramlib] [Open] [MOSSYS:LIBS/isobuilder.module.elf] [Read] [Fail]
    [51] [ramlib] [Load] [MOSSYS:LIBS/isobuilder.module.elf] [] [Fail]
    [52] [ramlib] [Open] [MOSSYS:LIBS/isobuilder.module] [Read] [Fail]
    [53] [ramlib] [Open] [MOSSYS:LIBS/isobuilder.module] [Read] [Fail]
    [54] [ramlib] [Load] [MOSSYS:LIBS/isobuilder.module] [] [Fail]
    [55] [ramlib] [Open] [LIBS:isobuilder.module.elf] [Read] [Fail]
    [56] [ramlib] [Open] [LIBS:isobuilder.module.elf] [Read] [Fail]
    [57] [ramlib] [Load] [LIBS:isobuilder.module.elf] [] [Fail]
    [58] [ramlib] [Open] [isobuilder.module.elf] [Read] [Fail]
    [59] [ramlib] [Open] [isobuilder.module.elf] [Read] [Fail]
    [60] [ramlib] [Load] [isobuilder.module.elf] [] [Fail]
    [61] [ramlib] [Open] [MOSSYS:LIBS/dtlibio.module.elf] [Read] [Fail]
    [62] [ramlib] [Open] [MOSSYS:LIBS/dtlibio.module.elf] [Read] [Fail]
    [63] [ramlib] [Load] [MOSSYS:LIBS/dtlibio.module.elf] [] [Fail]
    [64] [ramlib] [Open] [MOSSYS:LIBS/dtlibio.module] [Read] [Fail]
    [65] [ramlib] [Open] [MOSSYS:LIBS/dtlibio.module] [Read] [Fail]
    [66] [ramlib] [Load] [MOSSYS:LIBS/dtlibio.module] [] [Fail]
    [67] [ramlib] [Open] [LIBS:dtlibio.module.elf] [Read] [Fail]
    [68] [ramlib] [Open] [LIBS:dtlibio.module.elf] [Read] [Fail]
    [69] [ramlib] [Load] [LIBS:dtlibio.module.elf] [] [Fail]
    [70] [ramlib] [Open] [dtlibio.module.elf] [Read] [Fail]
    [71] [ramlib] [Open] [dtlibio.module.elf] [Read] [Fail]
    [72] [ramlib] [Load] [dtlibio.module.elf] [] [Fail]
    [73] [ramlib] [MakeDir] [ENVARC:FryingPan] [] [Fail]
    [74] [ramlib] [MakeDir] [ENV:FryingPan] [] [Fail]
    [75] [ramlib] [Open] [MOSSYS:LIBS/NListtree.mcc.elf] [Read] [Fail]
    [76] [ramlib] [Open] [MOSSYS:LIBS/NListtree.mcc.elf] [Read] [Fail]
    [77] [ramlib] [Load] [MOSSYS:LIBS/NListtree.mcc.elf] [] [Fail]
    [78] [ramlib] [Open] [MOSSYS:LIBS/NListtree.mcc] [Read] [Fail]
    [79] [ramlib] [Open] [MOSSYS:LIBS/NListtree.mcc] [Read] [Fail]
    [80] [ramlib] [Load] [MOSSYS:LIBS/NListtree.mcc] [] [Fail]
    [81] [ramlib] [Open] [LIBS:NListtree.mcc.elf] [Read] [Fail]
    [82] [ramlib] [Open] [LIBS:NListtree.mcc.elf] [Read] [Fail]
    [83] [ramlib] [Load] [LIBS:NListtree.mcc.elf] [] [Fail]
    [84] [ramlib] [Open] [NListtree.mcc.elf] [Read] [Fail]
    [85] [ramlib] [Open] [NListtree.mcc.elf] [Read] [Fail]
    [86] [ramlib] [Load] [NListtree.mcc.elf] [] [Fail]
    [87] [ramlib] [Open] [LIBS:NListtree.mcc] [Read] [Fail]
    [88] [ramlib] [Open] [LIBS:NListtree.mcc] [Read] [Fail]
    [89] [ramlib] [Load] [LIBS:NListtree.mcc] [] [Fail]
    [90] [ramlib] [Open] [NListtree.mcc] [Read] [Fail]
    [91] [ramlib] [Open] [NListtree.mcc] [Read] [Fail]
    [92] [ramlib] [Load] [NListtree.mcc] [] [Fail]
    [93] [ramlib] [Open] [PROGDIR:LIBS/NListtree.mcc.elf] [Read] [Fail]
    [94] [ramlib] [Open] [PROGDIR:LIBS/NListtree.mcc.elf] [Read] [Fail]
    [95] [ramlib] [Load] [PROGDIR:LIBS/NListtree.mcc.elf] [] [Fail]
    [96] [ramlib] [Open] [PROGDIR:LIBS/NListtree.mcc] [Read] [Fail]
    [97] [ramlib] [Open] [PROGDIR:LIBS/NListtree.mcc] [Read] [Fail]
    [98] [ramlib] [Load] [PROGDIR:LIBS/NListtree.mcc] [] [Fail]
    [99] [ramlib] [Open] [MOSSYS:LIBS/mui/NListtree.mcc.elf] [Read] [Fail]
    [100] [ramlib] [Open] [MOSSYS:LIBS/mui/NListtree.mcc.elf] [Read] [Fail]
    [101] [ramlib] [Load] [MOSSYS:LIBS/mui/NListtree.mcc.elf] [] [Fail]
    [102] [ramlib] [Open] [MOSSYS:LIBS/mui/NListtree.mcc] [Read] [Fail]
    [103] [ramlib] [Open] [MOSSYS:LIBS/mui/NListtree.mcc] [Read] [Fail]
    [104] [ramlib] [Load] [MOSSYS:LIBS/mui/NListtree.mcc] [] [Fail]
    [105] [ramlib] [Open] [LIBS:mui/NListtree.mcc.elf] [Read] [Fail]
    [106] [ramlib] [Open] [LIBS:mui/NListtree.mcc.elf] [Read] [Fail]
    [107] [ramlib] [Load] [LIBS:mui/NListtree.mcc.elf] [] [Fail]
    [108] [ramlib] [Open] [mui/NListtree.mcc.elf] [Read] [Fail]
    [109] [ramlib] [Open] [mui/NListtree.mcc.elf] [Read] [Fail]
    [110] [ramlib] [Load] [mui/NListtree.mcc.elf] [] [Fail]
    [111] [FryingPan] [Open] [muidebug] [Read] [Fail]
    [112] [FryingPan] [Open] [MagicWB] [Read] [Fail]
    [113] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui.elf] [Read] [Fail]
    [114] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui.elf] [Read] [Fail]
    [115] [ramlib] [Load] [MOSSYS:LIBS/mui/Title.mui.elf] [] [Fail]
    [116] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui] [Read] [Fail]
    [117] [ramlib] [Open] [MOSSYS:LIBS/mui/Title.mui] [Read] [Fail]
    [118] [ramlib] [Load] [MOSSYS:LIBS/mui/Title.mui] [] [Fail]
    [119] [ramlib] [Open] [LIBS:mui/Title.mui.elf] [Read] [Fail]
    [120] [ramlib] [Open] [LIBS:mui/Title.mui.elf] [Read] [Fail]
    [121] [ramlib] [Load] [LIBS:mui/Title.mui.elf] [] [Fail]
    [122] [ramlib] [Open] [mui/Title.mui.elf] [Read] [Fail]
    [123] [ramlib] [Open] [mui/Title.mui.elf] [Read] [Fail]
    [124] [ramlib] [Load] [mui/Title.mui.elf] [] [Fail]
    [125] [ramlib] [Open] [muidebug] [Read] [Fail]
    [126] [FryingPan] [Open] [MagicWB] [Read] [Fail]
    [127] [FryingPan] [Open] [MagicWB] [Read] [Fail]
    How do you post an attachment so the txfile doen't take up all this room?
  • »22.11.09 - 12:57
    xyphoid
    Problem solved bad file :-)
    morphos on the other hand tends to not pick up blank cd'd or hangs on them. makes it hard to eject media, which isn't recognized, even though it's in there. I used makecd to eject.
  • »22.11.09 - 17:59
