CED on MorphOS 2.4
    osco
    Posts: 680 from 2009/10/20
    Awhile back I backed up my Amiga Forever set up on a windows laptop..I copied it on a USB stick.
    MorphOS can access the USB stick to a point. In one of the drawers was an Icon for CED.. Clicking on it brought the application up and working to a point.. I had many Arexx scripts in the "S" directory which CED saw ...but opening the file produced and empty page? Is it a path problem...maybe look into the CED preferences?
    Osco seen trudging into the cave again  :-?
  • »20.11.09 - 01:15
    Krashan
    Posts: 1107 from 2003/6/11
    To make ARexx scripts working, copy also rexxsyslib.library and overwrite the one located in MOSSYS:Libs.
  • »20.11.09 - 02:58
    Might be a better suggestion to rename the MorphOS rexxsyslib.library file with an _OLD extension and then copy the rexxsyslib.library file from your AmigaOS3.x disk, or CD to the MOSSYS:Libs directory.
  • »20.11.09 - 05:02
    CISC
    Posts: 619 from 2005/8/27
    @Krashan & amigadave:
    Double-fail. ;)
    Do not put the original rexxsyslib.library in MOSSYS:Libs/, but rather in SYS:Libs/ and rename/delete the one in MOSSYS:Libs/.
    The reason for this is simple; the next time you update MorphOS MOSSYS: will be replaced, thus if you put it in SYS:Libs/ all you have to do is rename/delete the one in MOSSYS:Libs/ again...
    Anyway, I think osco's problem was something else, he complained opening a file turned up empty; not running an ARexx script. I'm not sure what the issue is, but AFAIK CEd works just fine in MorphOS 2.4 (though there is a native version available for owners of CEd (I don't know if the patch applies to osco's version however)), it's possibly a configuration issue (same color on the text as the background)?
    - CISC
  • »20.11.09 - 05:20
    Posts: 3336 from 2003/3/5
    @ amigadave & Krashan
    Like CISC said, never copy anything to MOSSYS! Just delete the rexxsyslib.library located there and put your original one into sys:libs. This way, when updating MorphOS to 2.5, IWizard will NOT write MOSSYS:Libs/rexxsyslib.library when it detects one in sys:libs.
  • »20.11.09 - 06:08
    Korni
    Posts: 473 from 2006/2/23
    Here is a full and free CED for MorphOS. Patches are only for 68k version.
    http://aminet.net/text/edit/ced_mos_ppc_upd422.lha
  • »20.11.09 - 07:21
    Posts: 12572 from 2003/5/22
    > full and free
    "You need a properly installed MorphOS release as well as the original CygnusED 4 CD to install the PowerPC port"
  • »20.11.09 - 10:55
    Korni
    Don't install it then :). Just copy CED.elf to your favourite place and run it.
  • »20.11.09 - 12:17
    osco
    Solved :) changed a setting from workbench setting to global dispays
    ty
    al
  • »20.11.09 - 18:08
