BeeHive
    xyphoid
    Posts: 870 from 2008/7/11
    Anyone using beehive successfully??If so how? I csn't get to connect. It just cycle saying connecting but never connects and begin d/l. Don't really see what to configure , seems all standard. It's based off ctorrrent, but ctorrent works well.
  • »10.11.09 - 02:11
    clr666
    Posts: 85 from 2008/7/8
    I have similar issue
    _______________
    wintel free
  • »10.11.09 - 04:28
    hooligan
    Posts: 1948 from 2003/2/23
    Beehive havent been updated for a long time, so maybe it doesn't even work with every tracker today. Shape's not in Finland at the moment, and will not be for quite some time so better look for other working solution.
  • »10.11.09 - 05:08
    xyphoid
    ok. thanks for the info.
  • »10.11.09 - 16:51
    Posts: 5 from 2003/2/25
    I can't develop BeeHive now that I'm out of Finland and out of Pegasos, but there is a new version which I was working on, before leaving:
    0.3
    This is based on the newer version of ctorrent, which includes many improvements. Whether this fixes your problem or not, I don't know, and as mentioned, I can't look into it for a while. Let's hope it helps...
  • »10.11.09 - 22:01
    xyphoid
    @ Shape
    Always great to correspond to a developer. I didn't get it to d/l either....would give you my efika...but that's like going from what, a1200 to a500 :-)
  • »10.11.09 - 22:54
