Wildfire\7 ppc not installing?
    osco
    Posts: 680 from 2009/10/20
    Tried an automatic install may nreed a manual tweak?
    Any have this application on ?
    TIA
    osco :-?
  • »02.11.09 - 02:36
    Posts: 12543 from 2003/5/22
    The MorphZone search function presents the following threads:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=249&forum=9
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=3366&forum=9
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6266&forum=9
    Maybe a solution is to be found therein.
  • »02.11.09 - 03:06
    XzIt
    Posts: 250 from 2005/1/19
    are you using the *new* installer?
    try using classic installer, might be a problem there.
    you can find it on aminet i think and maybe in the mossys:c/ named classic_installer
    XzIt
    Mac Mini 1.25Ghz, 512Mb Ram, 32Mb Vram, 40Gig HDD
  • »02.11.09 - 10:21
