video streams owb-> mplayer
    xyphoid
    Posts: 870 from 2008/7/11
    moving away from ANR for mp3 streaming since I got that going as a default in OWB, how DO I input a type of command in owb to default mplayer(gmplayer) to play a video stream. Don't know how effective this would be or how fast on efika, but I'm willing to give it a try. Here's a linky to play with PBS
    Posted with OWB v1.4
  • »20.08.09 - 03:29
    dake
    Posts: 204 from 2007/9/14
    I have configured OWB to play avi's, mpg's. Im at work now so i probably give you some smaller errors:)
    I created a mime type, application/video and pointed to GMPlayer with %u or something:), so everytime i click on an video link it's played with GMPlayer.
  • »20.08.09 - 06:00
    dake
    hmm, some big corrections.
    mime type is video/*
    leave extension blank
    external viewer "Program:Grafik/MPlayer/GMPlayer >nil:" %l
  • »20.08.09 - 13:16
    xyphoid
    Thanks dake!
    this works great for sites with avi format as such. It works well on 1024x768 resolution on my efika but loses mem under
    1920x10.. I also used owb 1.3, as to conserve even more mem(1.4 seems to use more)
    Now streams like the one in thefirst post (pbs) yahoo video, and winampaol....these are a completly different beast? or could something similair be configured? getvid works for youtube, but what if you're not browsing youtube videos?
    [Posted with OWB v1.3]
    [ Edited by xyphoid on 2009/8/20 16:15 ]
    [ Edited by xyphoid on 2009/8/20 16:31 ]
  • »20.08.09 - 18:09
  • Visitor
  • if you mean with getvid the getVideo project that is released on aminet,
    then it does of course not only work with youtube.
    getVideo has currently support for more then 30 sites.
  • »21.08.09 - 10:13
    xyphoid
    True, but the sites mensioned are unsupported
  • »21.08.09 - 11:52
  • Visitor
  • hmm ... this looks not good ... this site use rtmp stream
    rtmp://pbs.fcod.llnwd.net/a1863/o6/tp-live/PBS_CP_The_NewsHour/pbsnh081409_448k.mp4
    but you can download using rtmpdump
    rtmpdump -r "rtmp://pbs.fcod.llnwd.net/a1863/o6/tp-live/PBS_CP_The_NewsHour/pbsnh081409_448k.mp4" -o outfile.mp4
  • »21.08.09 - 13:59
    xyphoid
    @antibike
    This should be a great solution for now. I'm not familiar with rtmp, which seems to bring up the exact stream, so please enlighten me a bit more in usage and program
    thanks!
  • »21.08.09 - 22:16
    xyphoid
    Getvideo pre.22  ;-)
  • »26.08.09 - 01:08
    manga
    Posts: 41 from 2009/5/6
    i tried to look a video of the german ard mediathek. getvideo wants "rtmpdump" to save the video stream on harddisk, but rtmpdump isnt included in the getvideo package.
    tried to look at https://code.launchpad.net/rtmpdump and aminet but cant find a binary version for morphos. could someone point to the right direction? thx in advance.
    Powermac MDD 1,25GHz Radeon 9000 Pro 128MB, 1,5gb, Terratec Aureon Space, USB2.0 NEC, MorphOS 2.6 regged, Powermac MDD Dual1.42, Radeon X800XT PE 256MB waiting for r300 support, Mac Mini 1.5GHz MorphOS 2.6 Regged, Efika Radeon 9250 128MB Morphos 2.6
  • »20.10.09 - 07:54
    xyphoid
    it should be included in the folder which says copy to c
  • »20.10.09 - 21:59
