Posts: 2074 from 2003/6/4
SnopDos doesn't tell me any hint. The weird thing is, that opening a project works (i.e. here the asl requester actually does work). The same is true when using import on the Efika under 2.3 (that locks when placing the sample), but it fails when using import on the Peg - no matter whether 1.4.5 is used or 2.3. Weird.
Well in the end PSA does work again on my Peg, I did a parallel installation and that works - soemhing must have happen with my original installtion...
On Efika it doesn't matter to much when it does not run, teh device is to powerless anyway (but it it ran, it wouldn't be a disadvantage).
[ Edited by Zylesea on 2009/9/8 0:16 ]
