VNC Server with MorphOS 2.3
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hello guys,
    does someone use the VNCServer with MorphOS 2.3?
    I somehow got the feeling with MorphOS 2.3 it even
    got slower, using more CPU power than b4.
    Could somebody crosscheck? Somehow have the feeling
    it was much faster in the past. Now it uses 100% CPU Power.
    Maybe something is causing unnessesary screen updates?!
  • »17.08.09 - 13:01
    Posts: 3274 from 2003/3/5
    Try disabling multibuffering in Enhanced Display settings. If that doesn't help, don't use Enhanced Display Engine for screens you want to use with VNC.
  • »17.08.09 - 13:30
    dIGIMAN
    Thanks,
    disabling the multibuffering did the trick.
    Wouldnt it be a nice idea to have a certain communication between the server and, well the layertask? So that on remotecontroll the enviroment could be switched to a remote controll friendly setting.
    Just thinking of ultravnc on windows for example, that remove the background picture, well somebody remotecontrolls a machine.
  • »18.08.09 - 12:02
    Yes, this is planned at some point, but I have no idea when it's going to happen.
  • »19.08.09 - 08:03
    dIGIMAN
    Ok, thats good news.
    ATM i can live good without multibuffering. VNC Speed is more important for me as i use it daily
  • »19.08.09 - 09:20
